Yanmar YM2000 Fuel Pressure/ hard starting
   / Yanmar YM2000 Fuel Pressure/ hard starting #211
If you cut off the tractor with the box blade raised, and it drops back down on its own, sounds like piston seal leaking.
   / Yanmar YM2000 Fuel Pressure/ hard starting #212
Mine drops also when it's not running. But slowly. Don't bother me. I lower everything anyways and if I want to keep it raised for Maint. etc. I'll lock it up and then it does stay..................;)
I agree, mine now doesn’t just fall, it’s a slowish decent when I turn the tractor off. I am not doubting there may be a seal leak, but it works well enough for me to be okay with its operation, and nothing too abnormal from other tractors I’ve worked with.
My project this week is figuring how to adapt the cross member from the 336D fitting YFL1500 front loader to fit my little YM2000BD.
After searching a few pictures and some sent over by California, I think I致e got a plan figured out.
Also, I致e found that the tach/hour meter cable did in fact break internally, so I am waiting for the new one to get here from Hoye.
   / Yanmar YM2000 Fuel Pressure/ hard starting #215
Glad to hear it's working ok and you found the tac problem.
   / Yanmar YM2000 Fuel Pressure/ hard starting #216
the arms will take the handle being almost all the way back to get the arms all the way to the top, but i will cram my top link into the ROPS structure long before that occurs usually and no more than 3/4 up is really ever needed with pretty much any implement to lift it high enough to be out of the way, where i leave the handle the implement stays. My valve is worn, i have replaced my big oring in the 3pt cylinder and every oring that i can when i took apart the valve, it just is what it is. Mine leaks when i turn the tractor off, the implement will slowly leak down. While running it does not move.. EXCEPT when i lift an item at idle for example and then throttle up to operating rpm it may move up an inch or so with the increase in fluid pressure. And the same when i am running and have it in the air and come back to idle it will settle down just a tad bit lower but happens so slow unless your watching where the arms line up on the tire or how many inches the deck is above the ground you wont notice it. THis is just how it is, i have talked to Steve and Aaron at HOye, they both said why does it matter your making an issue where there is none. Their point is it works, its a 40 year old tractor and some parts are just worn. Said when it wont work anymore then get a new one or a serviceable replacement. I just like things to work as designed was my response. Which is why i tore into it in the first place. The o ring was worn but just a tiny bit, it barely if at all leaked down with the service stop closed, but it did more of the up down with the engine rpms than it does now with the old one on. Now when the stop valve under the seat is closed it will stay up forever telling you that the 3pt is fine but when open it leaks down meaning that the valve is letting pressure out of it.
   / Yanmar YM2000 Fuel Pressure/ hard starting #217
what's with the weird contractions or the way that it printed them....the way it wrote "I've" is my guess?
   / Yanmar YM2000 Fuel Pressure/ hard starting #218
I thought it was Japanese or Chinese writing.
I have discovered this site does that repeatedly with contractions for some reason.
   / Yanmar YM2000 Fuel Pressure/ hard starting #220
Must be on a pc, never had a problem on my phone.
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
2012 Ford F-350 Reading Service Truck (A51692)
2012 Ford F-350...
INMY Manual Landing Gear (A51692)
INMY Manual...
BUYERS PREMIUM & PAYMENT TERMS (A53426)
BUYERS PREMIUM &...
2020 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2020 Ram 1500...
