Yanmar YM2000 Fuel Pressure/ hard starting
   / Yanmar YM2000 Fuel Pressure/ hard starting
did you order the single joy stick or the double handle ?
Single joy stick.
The one this loader came with used to be a double handle, but the rods have been broken off and welded and broken off again, and it’s all rusted up.
So I saw what Hoye sells, and was going to buy that one but decided to look around.
There are 10gpm and 12gpm versions, so I went with the 12.
2 Spool 12 GPM Joystick Loader Control Valve | Joystick Valves | Hydraulic Valves | Hydraulics | www.surpluscenter.com
   / Yanmar YM2000 Fuel Pressure/ hard starting #242
And your tractor won't come close to ever producing more than 5gpm!! Haha. I'm pretty sure it's more like 3.5gpm.
   / Yanmar YM2000 Fuel Pressure/ hard starting #243
I wonder if its hard to feather a delicate lowering of the loader when valve capacity is much larger than pump capacity. Anybody know?
Fair enough, I figured opportunity for more flow would be better.
Oh well. I can always go to a smaller one if needed.
It could be a possibility, but when I find out I’ll be sure to let you know! Haha
   / Yanmar YM2000 Fuel Pressure/ hard starting #246
I see your point and I usually think that way but when the option that was listed is over 2x what you could ever dream of I think you have the excess capacity your after?
I don't know if it would be harmful toward performace (no where near a hydraulics expert or even a wanna be), I don't think so though, just that I can flow that much if required to.
Just look at it this way, if I ever sell the loader someone can put it back on a larger tractor and not have to worry.
Most of the valves I saw were 10-12gpm though. Even the one Hoye sells is 10gpm.
   / Yanmar YM2000 Fuel Pressure/ hard starting #248
Gotcha. I know you said hoye was 10gpm that's what I mean that one alone was plenty. But I guess if someone needs that extra capacity and you sell it, it's there. But I can't imagine you selling this loader...I guess if it just doesn't work right, you would but who sells a loader off their tractor that works. Haha
   / Yanmar YM2000 Fuel Pressure/ hard starting #250
FYI I'm pursuing answers to that question in this thread on the hydraulics subforum if anyone wants to follow along FEL and Rear T&T Control Valve Flow Capacity Questions
FWIW for my YFL-1500 FEL the recently installed Brand Hydraulics LV22RFSTKAB (same as sold by Hoye, nominal 10 GPM) is giving very satisfactory control on my 336D with a rated pump flow of 8.4 GPM. I'm happy with the valve though admit I didn't buy from Hoye.
I asked the questions in the hydraulics subforum because I'm still searching for a valve-set to add Rear Aux T&T (where I want good feathering control) and one other DA cylinder control and the 'best choice' isn't quite as apparent for that application. I wanted to confirm that the 'close capacity match' is a selection criteria I needed to maintain.
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
UNVERFERTH 210 LOT IDENTIFIER 16 (A53084)
UNVERFERTH 210 LOT...
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
