Yardmachine MTD FEL build diary
   / Yardmachine MTD FEL build diary #11
finally got the lifting arms made to the right length and started welding pivot points <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=423620"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=423621"/>
Looking nice. Now what color is the whole thing going to be
   / Yardmachine MTD FEL build diary #12
What do you have planned for braces?
I had to run mine to the rear.
Yeah i will make it a pretty colour when its finished (if I ever get it finished :laughing:)
I was going to brace it pretty much where you drew that arrow, from the side of the upright down to the front bar, what material did you use for your braces?
sorry re read the question I am thinking a nice racing green for the colour.
   / Yardmachine MTD FEL build diary #15
I used some light weight 1 inch tubing, flattened the ends and drilled holes to bolt to existing bolts. Since my braces are under tension with a load, the tubing was too thin and the holes ripped out.
I put on some thicker wall tubing with additional bracing. It is holding up well.
Hey guys tore a tendon in my knee so have not been doing a whole heap. this is the latest update on the project, cylinders are mounted, bucket is mounted just waiting on some hosing then i can test the actuation of pivot points, After that all checks out i will weld out the rest of the bracing (just in case some modification is needed).
   / Yardmachine MTD FEL build diary #20
Looking mighty fine
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
Misc Vehicle Brake Kits (A54816)
Misc Vehicle Brake...
2002 International 9200i Truck (A55315)
2002 International...
2017 Freightliner Bucket Truck (A55973)
2017 Freightliner...
2021 Kubota SVL75-2 Track Loader (A55315)
2021 Kubota...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
