leonz
Super Member
Chuck -- I've sent you a PM.
All -- I'm a bit confused, probably due to my complete lack of knowledge on 'best price' and how much attachments cost.
So I ask this question with open honesty; I'm not at all attached to that 7610... but doesn't the inclusion of a backhoe and snowblower account for the price on that used tractor? And the low hours? (132 hrs seems low to me. No? Yes?)
For comparative purposes: The same dealer quoted us $25,800 for a new B2320, same equipment.
Editing to add: You are an amazingly helpful group of folks!! Thank you all SO much for this input!!!
As long as you are shopping:
Seriously;
You should ask Brady and Steve Barlow for a price for a BX2660 or an L with a Kubota Deluxe Cab with all weather cab with air conditoning and heater.
Be sure to ask for the deluxe Kubota seat that also swivels so you can use a rear mounted snow caster.
Please contact Ken Sweet for a price for an Allied Farm King snow caster as he is a forum sponsor in good standing. He ships to all his customers from his warehouse in Kentucky.
With regard to snow casters you have to look at one thing, and one thing only which is the size of the "impeller drum" which is the business end of things.
The larger the impeller drum in diameter width and height the greater the snow casting ability.
For example the Group 2 snow casters built by Pronovost have impellers up to 34 inches in diameter with an 12 inch deep impeller drum so you have to be sure you have a very large impeller for the snow caster.
The front mounted snow casters have a smaller impeller drum in most cases as the snow casters size is limited by the underframe mounting system and the propeller shaft arrangements from the mid mount P.T.O. forward.
The front mount snow casters are also limited to the machine that they are mounted on and lose trade in value as they can not be mounted on other machines in most cases, whereas a rear mounted snow caster can be mounted on a new machine with ease as the larger ones are group two mounting systems.
You lose much less value with rear mounted snow caster as it can be mounted on larger machines.
And driving in reverse with the rear hydro pedal is not hard to do as you can simply twist slightly in the seat and use your left foot to push the reverse pedal down and braking is esasy as the snow caster will become an anchor as it is being pushed on the ground and it will create a large amount of drag to stop the BX or L quickly.
You can buy a wider snow caster with no worries as it will still be an excellent snow removal tool and you wil be able take half cuts at a higher travel speed and you will never be underpowered as the design of the rear mount snow casters will pull all the deep snows into the impeller.
With regard to mowers you should also ask Ken Sweet about his line of flailmowers as a flailmower can be used for lawn mowing and pastures as well as trails with less work and much better mowing.
The flail mower with its design will not throw things like a rotary mower will if it impacts them and is safe to use around 2 and 4 legged rug rats and especially along ditches and mowing a yard.
You should also look at our flailmower threads to see the advantages of a flailmower and there are lots of good before and after photos too.
