Yikes! Is it Winter where you are?
   / Yikes! Is it Winter where you are? #42
-32C this am, or -25.6F, -37C or -34.6 with the wind chill. I was scraping snow off the skating rink yesterday in the back yard with my GC2310. Started no problem....since I'm using 5W30 synthetic oil and have the block heater plugged in :) I started using Wal Mart outboard/snowmobile 2 cycle oil at 1:125 ratio this fall since starting to use it in my 98 Cummins diesel. They've both started without a hitch. This 2 cycle oil really does act like an anti-gel, plus improves lubricity of ULSD.
   / Yikes! Is it Winter where you are? #43
I can't imagine all the snow and ice you fellows have to deal with! I have lived in south-central NC my whole life. We may have a few inches of snow a year. Most of the time we don't even get that! I guess it's not that bad here after all. The main problem here is the upper 90'sF and high humidity in the summer time. Sorry guys I shouldn't be talking about all that heat in January!
Good Luck with all your snow blowing and shoveling!!!!:)
   / Yikes! Is it Winter where you are? #44
Yes, it is Winter here too. But, at least we get some warm snow.
   / Yikes! Is it Winter where you are? #45
We've had the coldest November and December since we moved here to Virginia in the fall of 2000 but no significant snowfall yet. Had one dusting. I haven't put my back blade on yet. Still have the chipper/shredder on and will probably use it again today to shred up some downed limbs from all the wind we had recently.
Ralph
   / Yikes! Is it Winter where you are? #46
LMAO! Love the pic.
From our local Environment Canada weather service data:
Yesterday
Max:
-17.4ーC
Min:
-34.4ーC
But today it's -16C and we're getting 7cm of snow. It's actually very pretty. Had some friends over yesterday and 5 kids were outside skating for quite a while.
   / Yikes! Is it Winter where you are? #47
Ralph
From Where ?
   / Yikes! Is it Winter where you are? #48
We are just starting to get to the REALLY cold part of the year for Minnesota.
I'm from Michigan and used to winters but the first year I moved here I found out what cold is all about. 36 days in a row where the temp didn't even get above 0 degrees F. Temps like -15 to -35 F and windchills at times hitting
-70 F. The close the roads some days because its to cold. If your car stalls and your stranded you can kiss your butt good bye.
   / Yikes! Is it Winter where you are? #49
Why'd Ya move from worse to worser?
L B
2005 JLG 660SJ TELESCOPIC MANLIFT (A52705)
2005 JLG 660SJ...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2008 Ford F-250 (A55218)
2008 Ford F-250...
Adams 6Ton Hydraulic Lime Spreader (A55301)
Adams 6Ton...
2015 Kia Cadenza Sedan (A53424)
2015 Kia Cadenza...
