YM 2500 rehab..multiple questions please
   / YM 2500 rehab..multiple questions please #11
tallyho8 said:
I have a 2wd YM1802 with a frontend loader and am very satisfied with it. You have to use a little common sense with a loader, whether you have 2wd or 4wd, and avoid overloading it when possible and always keeping your load as low as possible.
I have (unwisely) overloaded my bucket many times putting 700 pounds more on my front wheels than their load rating, while trying to keep my load close to the ground and avoiding holes and rough terrain. These Yanmars are extremely tough machines that can handle lots of abuse but they are easy to tip over with a loader if you are not careful.
I just moved a 12x12 creosote beam that weighed well over 1000 pounds before I cut 5 feet off it with no problems taking it slow and easy. (see photo)
Loaders on 2wds are extremely useful and handy to have but just are not quite as safe or able to handle as much weight as on a 4wd.
Wow. Where did you find that beam? Gonna make a bench?:D
   / YM 2500 rehab..multiple questions please #12
This is driftwood. I live on the River Road on the banks of the Mississippi River. I got a few of these last year off the banks. They are probably from ship docks that have been damaged upriver. I would hate to hear how much they sell for. I am building a small building and using them to make a very strong foundation in case I decide to move it to another location. (a little overkill) I will start a thread soon on this building made mostly of driftwood and salvage from Katrina.
   / YM 2500 rehab..multiple questions please #13
Sounds to me like a used tractor.
Metric bolts are available at most auto parts stores. Any bolt that doesn't need to be metric (has its own nut), I would simply convert to SAE if you don't have a ready source. Metric bolts are very easy to size, just stop into your local auto parts store and have them explain how the sizing works.
Your lights are probably fine, but would benefit from removing and cleaning. Most light problems are due to a bad ground, the ground usually being the bolt holding it to the tractor. Removing and wire brushing the attachment, then providing a clean surface before remounting will fix 95% of your light difficulties. If it still doesn't work, pick up a 12v tester (looks like a screw driver with a light and has a wire coming out the end) or a multimeter and check continuity. By grounding the clip (on the tractor) and touching the light socket center (with the light switch on and the bulb out), your tester should light up. If it doesn't, run a ground wire from the clip to your battery ground and try again. If it lights, you have a bad ground (see above), if not, your circuit is faulty. If the circuit isn't working, instead of testing the socket center, try following the wire back to it's orgin and test it there. (The reason the tester has a sharp point is so you can push it through the plastic covering and touch the wire beneath). Works? Replace the wire. Still doesn't work? Test each side of the switch. Only one side of the switch has power regardless of on / off? Replace switch. Keep following back until you find power and you will see what needs replacing. Just start at the light socket and move backwards.
Make sure you are not smelling a burning belt. If your alternator is burnt up, it's easy to replace. If not, it is easy to overhaul it by replacing the bearings and cleaning up the armature.
I think you have probably made a good buy and it sounds like you enjoy the process, which makes it all the better. My previous tractor was an Iseki TU205 4WD that I picked up cheap because it was broken in half. I removed the axles, engine and transmission, remanufactured the frame and it has survived exceedingly heavy use for years (loader). There isn't anything you can't fix on a tractor.
Currently working with a Yanmar YM240D. Really like it. Reminds me of a John Deere model M I used to use in the 70's.
   / YM 2500 rehab..multiple questions please #15
The nice thing about having the tractor forum is that someone doesn't have to live next door to lend a hand. This makes us all virtual neighbors.
   / YM 2500 rehab..multiple questions please #16
Yes, you are correct. Thats a good way to put it.
Travis_R
1996 LUFKIN 45' X 96' SPRING RIDE EXTENDABLE (A59575)
1996 LUFKIN 45' X...
Chevy 2500HD (A56436)
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
UNUSED JCT 72" HYD 4N1 BUCKET (A52706)
UNUSED JCT 72" HYD...
KOMATSU WA270 (A58214)
