ym1500 info on fitting a tipper pipe?
   / ym1500 info on fitting a tipper pipe? #1
billymc
south west scotland
yanmar ym1500 also massey ferguson 35 son
ok guys i have a green ym1500 ywo wheel drive i have a log splitter. will the tym 1500 run it? and if it will what conections and fittings do i need to do the job and where do you take the conection from? thanks
   / ym1500 info on fitting a tipper pipe? #2
as they told me a few years ago it will run it, but the cycle speed will be painfully slow, as the pump does not pump much . U can splice into your main hydro lines like they do for a loader. Not sure if ur tractor ha ports on the valve like some others do but if so that could be an option. i know the hydraulic 3pt head has all kinds of ports on it on my ym2000 but no idea what there for.
   / ym1500 info on fitting a tipper pipe? #3
I think the stock 1500 pump is good for about 3gpm. Your logsplitter should have a recommended gpm for operation. I'm thinking you will have to tap into you pump discharge line if you go that route. Remote hydraulic install on a Yanmar
   / ym1500 info on fitting a tipper pipe? #4
Here is a link to a video from another website I used to go to that clearly explains how to do the tap into, although is kubota it will be the same principle,
How to Tap into Hydraulic Lines - YouTube
He stated could have welded or brazed, However there are hard-line compression fitting available that work for this purpose as well,;)
thanks guys its a home made log splitter with a old excavator ram . my old mf35 was slow but could burst the logs no problem . other way im thinking is px the ym1500 fpor something a bit bigger with 4x4 and tipper pipe on it what compact do you guys think and what has a good pump for doing a log splitter? thanks Billy
   / ym1500 info on fitting a tipper pipe? #6
i run one on a ym1600 runs good.i like it.i cut the line and go in and out.
   / ym1500 info on fitting a tipper pipe? #7
have you give much thought in installing a self contained hydraulic circuit and fluid reservoir onto the log splitter? you could then use a PTO driven pump and would sure to give you all the gpm it needs, although note: that having moving parts ( PTO spinning ) while working at the rear of the tractor wouldn't be the safest method,
o the log splitter is a shared one with another farmer so not sure about that. as i said i was thinking of a bigger compact than the ym1500 as i could do with 4x4 for some jobs so i was thinking more on the line of one around 20+ hp and with a tipper pipe ? only thing close here are chinese siromer i think they are jinma or yto tractors any ideas?
   / ym1500 info on fitting a tipper pipe? #9
ok i give what is a tipper pipe? i ge the idea from context just never heard of remotes called that?
o thats what we call them here or spool valves ?
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2016 Ford Expedition XLT 4WD SUV (A59231)
2016 Ford...
Informational Lot - Financing (A61306)
Informational Lot...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2017 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A60429)
2017 CATERPILLAR...
Toyota SR1-BET35 3,500 LB Stand-On Electric Forklift (A59228)
Toyota SR1-BET35...
