ym1601d head bolt torque questions
   / ym1601d head bolt torque questions #11
sandfarmer,
This may not help with your primary problem of starting the tractor, but I happened to replace my fuel bowl assembly recently and had some pictures handy showing the little screw and groove. This is the old damaged one.
When I bleed the lines, I start with the bleed screws at the fuel bowl and work my way downstream to the injectors. Sounds like you've got it bled, though.
Good luck getting it started.
I fixed it!!!
I had the valve clearances too tight.
there is so little valve spring pressure that i was opening the valve while setting it.
thanks for all the suggestions.
   / ym1601d head bolt torque questions #13
Good job!
It's usually something simple like that, isn't it?
2018 John Deere Z997R (A53317)
2018 John Deere...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2016 VOLVO VNM SINGLE AXLE DAY CAB (A59575)
2016 VOLVO VNM...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
2000 INTERNATIONAL 4900 CAR HAULER (A59575)
2000 INTERNATIONAL...
1995 Stoughton Enclosed Dry Van Trailer, VIN # 1DW1A5323SS900663 (A57453)
1995 Stoughton...
