buppy69
Platinum Member
pruntyc said:Tractors are made to run at a constant rpm, not changing all the time. You aren't suppose to work one at less than around 1800 rpms, so in most all cases the foot throttle is of little use. Maybe in Japan where they were made to be used there was a good reason for them, but not here. Not many tractors built here have ever had foot throttles, as there was no good use for them. If you are using it, you are probably using it at too low a speed for the good of the tractor.
That's the first time I've ever heard you can't use a tractor below 1800 RPM's. I used mine Saturday for 6 hours with a fertilizer spreader at 1000 RPM's. The engine would have a lock out if you weren't supposed to use it at low speed.
Eugene
