YM2210 injectors, fuel pump, problem??
   / YM2210 injectors, fuel pump, problem?? #91
The elimination of air bubbles in the supply line to the IP would suggest an air leak inside the pump/lines to the injectors.. You're video shows a lot of air getting in there somehow.. Did you run the tractor for a while after you unscrewed the tank cap? IF the vacuum inside the tank was the issue it will take running it for a while for the air to go back through the return line to the tank to clear it out..
Do you have a nipple coming off of the IP inlet that goes to the return line?
It ran for about 35min before the video, No nipple coming off IP to return, only off the injectors i have a return to the tank.
Thanks for your time and help on this!!
   / YM2210 injectors, fuel pump, problem?? #93
I would still check both hold downs on the pump.
Hey Winston1, if that was leaking at the two fuel lines off the pump, wouldn't it leak fuel there and not suck air?
   / YM2210 injectors, fuel pump, problem?? #96
When it's running, take the fuel cap off and look into the tank with a flashlight, you should see bubbles on the surface of the fuel.. just want to make sure you're return line isn't clogged, you never know..
   / YM2210 injectors, fuel pump, problem?? #97
WoW!!! When I was speaking of my Return to the tank wasn't anything that bad. 1000/times worse. Somethings wrong with the threads on the Inj. lines/Inj. Someone may have cross threaded them. Or used the wrong Tap Stand/Metric etc.. May try a thread sealant or even a tape and see what happens.
   / YM2210 injectors, fuel pump, problem?? #98
He cracked the lines to do the video..
I have did that and dont see anything,my return line is open. the return on this is not like others , the fuel return is very ,very, small amount, I asked about this before and it seems to be normal .
   / YM2210 injectors, fuel pump, problem?? #100
For that much air it's a pump problem. I think as much as Fire 260 has been threw the lines he would have found a leak by now. They or it would be wet from fuel leaking...JMO. with that much air/bubbles. If the Tank was causing a problem It takes time for it to build up pressure or Vac.
1997 international 4900 DT466E (A56435)
1997 international...
14C SCRAPER (A58214)
AUCTION STARTS HERE @ 9AM (A52708)
AUCTION STARTS...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56436)
PENDING SELLER...
2018 John Deere 1653 (A56436)
2018 John Deere...
Dump Hopper, 43" W x 39" D (A59076)
Dump Hopper, 43" W...
