Zerk fittings
   / Zerk fittings
Ok, I got my extraction tool, and I had to do a little work to get the pins in the flutes. They had some chips, burrs and such. Finally got all 4 pins in about a 1/4 inch and worked it back and fourth until it loosened up and it came out, thank God! I finally got time today to finish the job and got both sides drilled tapped and zerks in and greased. Good to go now!
Thanks for all the help and advice! Hope I don't have to do that again! Should not have had to do it in the first place! But, thanks again, this is a very valuable source for tractor people because of all the knowledge you guys have!
Now I just have to go and get a tree trunk off my mothers bridge in her driveway. Her waterline is directly under it so I will have to lift it off and I can't get to it with the bucket because of it being very narrow. I just hope I can lift it with the backhoe where I can swing it!
2017 Makita HM1307CB 35lb Demolition Hammer (A55973)
2017 Makita...
New/Unused Easy Clean Hot Water Pressure Washer (A54865)
New/Unused Easy...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2000 SCHWING P88 PORTABLE CONCRETE MIXER (A51247)
2000 SCHWING P88...
2016 CATERPILLAR 336FL EXCAVATOR (A52705)
2016 CATERPILLAR...
