ZTR recommendations?
/ ZTR recommendations? #41
firemanpat2910 said:
has anyone tried the older snapper zturn with the single joy stick control lever? my old boss had one and it was great, but I have not seen any more like it. He bought it new back in around 97 or 98. He has passed away since so I cant get the exact year or model # but I remember how easy it was to drive it and you only needed 1 hand
I never tried the Snapper, but my Country Clipper is joy stick. Didn't CC make the Snapper?
Anyways, you are absolutely right about ease to drive!!!
/ ZTR recommendations? #42
coobie said:
A comparable 2007 ferris ZTR I looked at had the 33 hp.Cat.diesel in it.What turned my away from the ferris was it was $3,000 bucks more the the kubota 326 pro
Isn't the Kubota ZD331 a better comparison to the Ferris Diesel? The 33HP Cat diesel has 7 more HP than the ZD326. I'm pretty sure the price difference between the ZD326 and ZD331 is probably at least $2000-$3000.
You probably could compare the ZD326 to the Ferris 4500 though:
IS® 4500Z Series, Ferris® Industries, Zero-Turn, Riding Mowers, Ferris Mowers, Mowers, Mower, Commercial Mowers, Lawn Mowers, Lawnmowers, Suspension, Independent Suspension, Munsville New York, Syracuse, New York, Central New York, Mohawk Valley,
Much closer in specs.
/ ZTR recommendations? #43
i do think you are right about the cat motor, i was trying to remember what else had a kubota diesel in it while i was at the john deere lawn and garden store. they sold ferris,jd,toro, and something else.
and yes the 33 hp ferris would compare to the zd331 both are 30hp+ and 72" cut. i think that was the ferris that weighed so much.
incedently i mow a friends yard and the rain just wont quit so he went out and bought an atwoods special pull behind your atv 60" cut 18 hp mower. Now that looks funny on a residential lot. :D
i think i might borrow it to mow mine since its raining again, its either that or hook a chain from the zd to the b3030 and have my wife pull me through the yard,lol
/ ZTR recommendations? #44
My kubota pro 326 60 inch deck was $10,700 the Kubota ZD331 I priced was $12,300 which is $1,500 more.The ferris 5100Z 33.5 hp.Cat.diesel 61 inch deck was $14,900.The ferris 4500z 28 cat.diesel 61 inch deck was $13,900.
/ ZTR recommendations? #45
Not sure of the price, but I believe the Scag Turf Tiger comes with a Kubota diesel. As far a sticking to a hill my gas engine Tiger feels like it is glued to the slope. Extra wide stance and 10 gallons of gas between the wheels instead of on top of them makes a big difference.
/ ZTR recommendations? #46
I have owned TWO ZTR's, one with a suspension and one without. I WILL NEVER BUY ANOTHER ONE. Suspension or not, flat yard or not, low tires or not these things will beat you to death. They are good for as sore neck, sore arms, shoulders and wrists. Sure fun to drive and they make quick work of the yard, but you will pay for it.
I now have a JD F910 with a front mount mower, great ride and drives like a ZTR. Heavy duty unit that will last a long time. These can be bought used for less than $7,000. These all have suspension seats. Kubota, Gravely and JD make great choices.
Good luck.
VV
/ ZTR recommendations? #47
Good luck.
VV
and new they are close to 20k, alot better unit overall i will admit.
/ ZTR recommendations? #48
The JD F910 and F930's can be had for less $3,000 used. My F910 was less than $2,000. A new engine (air cooled 18hp) and several other new parts had just been installed. My JD is a 2WD hydro with a 60" mower. Although 4WD can be had I would not think it would be necessary in Texas, sure isn't here in Ohio and I have a hilly 4 acres. Before I'd buy a ZTR, new or used, I'd be looking at a used front mount (ebay,for example) and give one a test drive. You will not be disappointed.
VV
/ ZTR recommendations? #49
VV
To each his own,but I love my kubota ZTR.coobie
/ ZTR recommendations? #50
good morning,
hustler 52/20hp honda, 88 hrs so far, 3+ac. in about 2 hrs..excellent fuel economy...serviced at 60 hrs. sharpen blades once a year(in the spring)....NO FLAMES here....would buy another in a heart beat.....
if you have never used a ZTR, take your time and have some fun...you will be surprized at how fast it is and, if you are worried about it being rough, get a good seat cushion....i love mine...
bluebonnet2
Craftsman 42 Inch Riding Mower (A57454)
Craftsman 42 Inch...
2018 MACK CHU613 (INOPERABLE) (A58214)
2018 MACK CHU613...
2025 AGT Industrial ATK-B1000 2 Post Car Lift (A60463)
2025 AGT...
John Deere 6300 (A60462)
John Deere 6300...
JLG 1230ES COMPACT ELECTRIC VERTICAL MAST LIFT (A59823)
JLG 1230ES COMPACT...
2022 John Deere R4023 (A60462)
2022 John Deere...
