John Deere 4510-1 4.70 star(s) (3)
Information, reviews, photos, discussion topics, owner pages, and specifications about the John Deere 4510-1.
25-50 HP Tractors
About the John Deere 4510-1
John Deere 4510-1 Discussions (7)
Here are the most recent 4510-1 topics from our community.
  1. B
    John Deere 4510 steering column removal
    My new to me 4510 tilt steering is not working properly. I’m stuck on how to remove the dashboard that holds the gauges. Any help on this and fixing tilt not working issue would be greatly...
  2. R
    Got my dream machine yesterday JD4510
    Well Gents I have been looking for about 2 years for the right 4500/4600/4700 or 10 series to buy. I wanted a smallish machine with a high lift capacity. I quickly learned while I like my 3032e...
  3. R
    John Deere 4510 tilt steering
    My JD 4510 tilt steering will not tilt anymore. Does anyone know how hard it would be to dig in to fix? Thanks
  4. H
    John deere 4510. Extreme high engine temp reading
    Temp gauge shows high water temp after 2-5 min engine idle. Try cooling temp sensor replacement How would you verify sensor is faulty.
  5. M
    John Deere 4510 rear brakes
    I have a Deere 4510 that makes a grinding noise when I hit the brakes. Figurin the brakes need changed but can't find any info on what's involved to change them. Any info would be appreciated.
  6. EMcPhee
    Box scrapper for a JD4510
    I'd like to put a heavy duty box scrapper on my JD4510. Can you recommend a size and brand that can stand up to some punishment on a rocky driveway? The local JD dealer thinks an 84" box...
  7. L
    JD4510 or Kubota L3830
    I have 15 acres, I will mow/bush hog pasture, move manure, haul wood,till gardens and move snow. I have till the end of the month to decide. Probally will go with hydro trans.Any advice will be...
[ad placeholder]
User Reviews (3)
Read what TractorByNet members think about the John Deere 4510-1 Subcompact Tractor
5
67 %
4
33 %
3
0 %
2
0 %
1
0 %
5.00 star(s)
jurissarins
4510-1 John Deere
Good Versatile Tractor
Model Year: 2002
It was purchased used from a farmer that needed a bigger machine. We use it to manage about 40 acres of forestland, maintain trails, brush-hog some meadows. Small enough to get in between trees, but can handle some decent size logs. We use it routinely with pallet forks to move skids of firewood and construction supplies. Reliability has been great, only one minor fluid leak on front drive unit, which was solved by re-torquing housing bolts. Starts easily in cold weather with no block heater.
Pros: Maneuverable, easy change attachments.
Cons: Need to reverse rear tires to install chains for winter snow clearing.
Photo Uploads:
5.00 star(s)
jctorrance
4510-1 John Deere
John Deere 4510 Compact
Model Year: 2002
I purchased a 4510 to use in for commercial landscape construction, building my house, and small scale farming of 10 acres of hay. I am really please with the tractor and it's many uses. I have a 6ft mid mounted mower to mow the yard, a backhoe to dig footers for retaining walls, you name it and I have probably done it with this tractor.
Pros: Versatility and ability to take on many tasks.
Cons: Premium price for filters and lubricants from the dealer.
4.00 star(s)
ellisd
4510-1 John Deere
JD 4510
Model Year: 2003
I have no complaints about this tractor. It starts easily, even in very cold temperatures, and it runs smoothly even when cold. I bought it used, and the previous owner used it hard and did not take the best care of it (it should have been greased more often and it was not garaged or cleaned at all). The vinyl seat has cracked, and it needs to be replaced, but everything works as it should. The tractor came with backhoe and loader. I am missing the 3-point hitch parts, and I am disappointed that the lower arms, sway blocks, and links cost well over $1,000 to buy from a dealer. I can get aftermarket parts for under $200, but I would rather have the original manufacturer's parts, since the quality is said to be much better. I have been holding off because of the price, and I am hoping to come across a used 3-point setup for this machine. I have another tractor to run my attachments, in the meantime.
Pros: runs good, very reliable
Cons: price of parts
[ad placeholder]
John Deere 4510-1 Owner Pages
View owner pages to see photos, customization and comments about member-owner John Deere 4510-1s
John Deere 4510-1 Community Rankings
#301 user rating of 2355 25-50 HP Tractors items
#279 Viewed of 2355 25-50 HP Tractors items
#402 discussed of 2355 25-50 HP Tractors items
#787 user rating of 19625 items overall
#668 Viewed of 19625 items overall
#969 discussed of 19625 items overall
