Branson 4720-1 5.00 star(s) (5)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Branson 4720-1.
25-50 HP Tractors
About the Branson 4720-1
Branson 4720-1 Discussions (26)
Here are the most recent 4720-1 topics from our community.
  1. B
    I HAVE A 2003 BRANSON 4720 .
    I HAVE A 2003 BRANSON 4720 . I REMOVED THE HYDRAULIC HOSES TO INSTALL A 3RD FUCTION FOR GRAPPLE. SINCE THEN THE REAR HYDRAULICS HAVE NOT WORKED . SO I PUT EVERY THING BACK STOCK AND IT STILL DONT...
  2. R
    Branson 4720 H parts.
    Need a TA00015460A front spindle . Seems no parts in canada. $732 if one can be found. HELP
  3. F
    Need service manual for 2015 Branson 4720.
    Any leads? Google drive fails to bring up the previous posted links…
  4. B
    Branson 4720 H how do you lock the rear DIff and drive
    The rear wheel different lock is behind your foot where the forward and reverse pedals are you can step on the rear of lock? But then you can稚 push on the forward or reverse pedals What Am I...
  5. F
    Branson 4720 price
    I am looking to buy a 2018 Branson 4720 with front end loader and hydro trans. I really have no idea what kind of mark up these machines have and its hard to find much info. My closest dealer is...
  6. T
    Branson 4720 battery bracket
    Just changed the battery in my Branson 4720H yesterday for the first time. I embarrassed and should've paid more attention when I removed it, but now can't get the battery bracket seated on the...
  7. K
    Branson 4720 fan shroud
    I can't say enough good so far about the Branson tractor after shopping for almost a year and now having it for two years and lots of hours. How simple and dependable it is and with any mechanical...
  8. sikmusicfreak8
    My 2005 Branson 4720 update
    Well, some may remember me purchasing a used 2005 Branson 4720, with the 8620 backhoe. Upon delivery I had some issues with what I was told from the dealer, etc. This was back in April. I fixed...
  9. B
    Just about to buy a Branson 4720 hydro Hydro
    Looking for any info and if this is a smart decision how have the 2016 Branson's been running. Are they planning any big updates in 2017 for the tractors
  10. U
    Branson 4720
    I have a 2005 Branson 4720 with the Ag tires. I have found a set of Kubota 6060 turf tires and wheels. size These are new take offs from a Kubota 6060. Front size is LSW 305 R 343 and the rear...
  11. J
    Branson 4720
    I was running my tractor and got off to do something. When I got back on, I put it in gear and it would not move. I moved the range from 3rd to 2nd. nothing happened. Any suggestions?
  12. R
    Branson 4720 back up lights.
    Have owned this tractor for 3 years now and never needed to use the lights . Last night I needed to snow blow so my wife could get out today. Had a really hard time as the back up lights would...
  13. R
    Branson 4720 3 PT hitch Hydraulics
    Having problems with the 3 point hitch on my Branson 4720. It will not move when the tractor is cold but after it warms up to operating temp it seems to work ok. I don't know if it's the relief...
  14. R
    Branson 4720 Battery
    Anyone know off hand what the cold Cranking Amps are in that tractor. Did nt see much in English writing on the battery. batteries 4-5 years old now and the first winter where it doesn't start...
  15. H
    Price Check Is a Branson 4720 with FEL worth $4k? 400 hours.....clutch sticks
    I've just stumbled on this tractor, and I think the answer is obvious. Original owner selling because he wants hydrostatic. Clutch was replaced at 260 hrs. Clutch pedal now sticks down....he...
  16. J
    Branson 4720 Issue
    Need help trying to figure out an issue I have been having with my 4720. Tractor has 180 hrs and is routinely serviced to the tee. I have had very few issues in the past with tractor and has been...
  17. M
    Oil & Fuel Branson 4720 won't make power
    My Branson 4720 was running fine one day than the next it started losing power. I was doing light work so work so I tolerated it at first. As the day progressed it got worse and had to shut it...
  18. M
    Branson 4720 PTO problem
    I have a seven year old 4720 with 700 hours. I just bought a five foot 3pt tiller and am having problems when engaging the ground. At first it was OK but after about 30 minutes the PTO shaft quit...
  19. H
    Branson 4720 clutch issue?
    Hello to all. First post on a great site. I have a 4720 with loader that to date (230 hrs.)has been a great machine.Recently I went to use the tractor and the clutch seems to be stuck in the...
[ad placeholder]
User Reviews (5)
Read what TractorByNet members think about the Branson 4720-1 Subcompact Tractor
5
100 %
4
0 %
3
0 %
2
0 %
1
0 %
5.00 star(s)
idmcimam
4720-1 Branson
Branson 4720H
Model Year: 2010
I researched a lot of compact tractors prior to making this purchase. Most of them were toy-like in their construction. This Branson is the best-built compact tractor I have ever seen. I have owned Kubota L2900 GST and Grand L5240 HSTC tractors in the past. Kubota has priced their tractors out of my range. This Branson isn't as fancy as the Kubotas, but IMHO it's construction is sturdier. The Kukje/Cummins 4 banger runs sweet and is very efficient. The HST tranny has 3 ranges and works well (my wife loves it!). QD front end loader is standard, not optional like Kubota. Tim Brown at Colorado Tractor Corporation is a GREAT dealer to work with. The only complaints I have so far are the metal sliding toolboxes under the deck are difficult to access and too short and the PTO switch design lends itself to accidental activation every time I turn in the seat. I'll be working on that.
Pros: Great value for the money.
Cons: Tool boxes. PTO switch.
5.00 star(s)
MMG
4720-1 Branson
Branson 4720
Model Year: 2004
I bought my 4720 in 2004 after looking at nearly every tractor manufacture in its class (45 to 50 hp). John Deere is king, but costs too much for my budget. Kubotas are too light (my Branson weighs 500 pounds more than a similar HP sized Kubota), and I did not like the New Hollands or Case tractors at the time. I have since put over 600 hrs on the machine with very little trouble. They only strange thing that happened was that I broke both tie-rod ends in the first two years. I replaced them both with Branson parts and have not had another problem. I have a loader, 6’ box blade, and a 6’ “bush hog”. The tractor handles them all quite well. I am considering buying a Branson 6530 with a cab once I can afford it. Feeding the cows will be a lot nicer in the winter. MosesR, Washington County, MO
Pros: Low cost; Heavy; Durable; Cummings power.
Cons: Little known, they may not hold value as well as others?
Photo Uploads:
5.00 star(s)
MMG
4720-1 Branson
I Love my Branson 4720
Model Year: 2004
I bought my 4720 in 2004 after looking at nearly every tractor manufacture in its class (45 to 50 hp). John Deere is king but cost too much for my budget. Kubotas are too light (my Branson weighs 500 pounds more than a similar HP sized Kubota), and I did not like the New Hollands or Case tractors at the time. I have since put over 600 hrs on the machine with very little trouble. They only strange thing that happened was that I broke both tie-rod ends in the first two years. I replaced them both with Branson parts and have not had another problem. I have a loader, 6’ box blade, and a 6’ “bush hog”. The tractor handles them all quite well. I am considering buying a Branson 6530 with a cab once I can afford it. Feeding the cows will be a lot nicer in the winter.
Pros: Heavy, reliable, & economical.
Cons: May not hold value as well as other big name brands.
Photo Uploads:
5.00 star(s)
razorbackfan
4720-1 Branson
Branson 4720h is a really good tractor
Model Year: 2010
I bought it about a month ago and have 8hrs so far. It's been a great tractor. I know it's still brand new but it's done everything I've asked it to do so far. I had the oversized industrial tires put on. I got the 0% for 60 month financing for the cash price because I almost walked on the deal. The only thing I wish I would've done was get the turf tires. I do mostly yard work and the industrial tires really start tearing the yard up during loader work. Makes for some hard mowing unless I go back across with a yard rake or blade. I'm not a fan of the brake being on the left on the Hydrostat. I would also think the rocker style fwd/rev would be easier than the separate pedals. If your not looking down at the pedals sometimes you'll miss it.
Pros: Best bang for the buck, great warranty, great financing
Cons: Brake on left and separate pedals for hydrostat
Photo Uploads:
5.00 star(s)
Anonymous Poster
4720-1 Branson
it's a great tractor
Model Year: 2005
I have had very good luck with this tractor and i am proud of my purchase. The only problem I had is I need to replace a u-packing seal on my hydraulic lift. For using it for 5 years O don't think that is bad.
Pros: all good
Cons: didn't get repair manual with the tracto
[ad placeholder]
Branson 4720-1 Owner Pages
View owner pages to see photos, customization and comments about member-owner Branson 4720-1s
Branson 4720-1 Community Rankings
#1 user rating of 2355 25-50 HP Tractors items
#123 Viewed of 2355 25-50 HP Tractors items
#215 discussed of 2355 25-50 HP Tractors items
#1 user rating of 19625 items overall
#254 Viewed of 19625 items overall
#495 discussed of 19625 items overall
