Mahindra 5525_2 4.00 star(s) (4)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Mahindra 5525_2.
25-50 HP Tractors
About the Mahindra 5525_2
Mahindra 5525_2 Discussions (12)
Here are the most recent 5525_2 topics from our community.
  1. S
    Mahindra 5525 instruments not working
    I've just joined this forum to get some help with this problem, which I see is a fairly common issue with Mahindra tractors. The tractor in question belongs to my gliding club and is used for...
  2. T
    Mahindra 5525 Hydraulic Fluid Check?
    Please forgive this embarrassing question, but the owner's manual just isn't clear to me. Where does one check the hydraulic fluid level on the 5525? There is a red topped plastic cap just behind...
  3. M
    2008 Mahindra 5525 - PTO will not stay engaged.
    PTO pops out. Lever will not stay engaged. does not feel as if it is latching properly. Also will not latch in neutral position to engage ignition interlock switch. Just happened while mowing...
  4. G
    Brakes on a Mahindra 5525?
    I recently purchased a 2011 Mahindra 5525. The question I have is about the brakes on this tractor. When I have it in gear and press the brakes the tractor does not stop, it bogs it down slightly...
  5. R
    Mahindra 5525 Wont Start
    Hi everyone, I think after 7 years I might have done the unthinkable, I ran my tractor out of diesel and now it wont start. I'll tell you now, I am not very mechanical, but I can turn a wrench...
  6. T
    Mahindra 5525 Hydraulics Sluggish
    All Hydraulics are sluggish front loader and the 3pt. Filter and oil was changed about 2 months ago, just use it a couple weeks ago to move roll of hay. Just today dropped the roll fork put on...
  7. scsims
    Mahindra 5525 Radiator Drain
    I'm planning on draining my coolant tomorrow. The manual says there's a drain plug on the left of the crank case and one at the bottom of the radiator. The plug on the left side is easy to find...
  8. WHW2821
    Buying Mahindra 5525
    I will be purchasing a new Mahindra 5525 for a small hay operation and wanted to know if the FEL will handle a 850 pound bale grab + 600 pounds of square bales in it. I know the loader capacity is...
  9. P
    Hydraulic fluid for Mahindra 5525?
    What kind of hydraulic fluid do I need to use for a Mahindra 5525? Thanks
  10. P
    spool valve for Mahindra 5525
    I'm looking to fit my 5525 tractor with a valve like Flusher's shown on the photos, I take it this would be an OC valve with power beyond and I would want to use double acting cylinders, which...
  11. M
    Mahindra 5525 with 509 bh
    I have searched the internet for hours looking for a book, dvd, program etc..for a quick tutorial re using a backhoe. All I found was tech schools and ojt. type sources. Anybody have a source for...
  12. M
    Mahindra 5525 2WD
    It seems today's tractors are a Heinz 57. The motor from one country, the transaxle from another, etc. Anybody know what motor is in the 5525 and what transmision. The Italian tranny that is in...
[ad placeholder]
User Reviews (4)
Read what TractorByNet members think about the Mahindra 5525_2 Subcompact Tractor
5
50 %
4
0 %
3
50 %
2
0 %
1
0 %
3.00 star(s)
Anonymous Poster
5525_2 Mahindra
Poor Quality And No Customer Support
Model Year: 2016
I purchased this new with high expectations only to be disappointed. The tractor has 48 hours on it and has been back to the dealer 4 times, as well as 3 service calls to the house. They have put more hours on the tractor that me. I have tried to get some type of customer service from Mahindra only to be still waiting for a call back or anything. This is not the Mahindra experience I was hoping for.
Pros: Low price
Cons: Poor quality, constant problems
3.00 star(s)
gerow
5525_2 Mahindra
Mahindra 5525
Model Year: 2010
Tractor was great for the warranty period now it is nothing but a headache. Front axle spindle snapped off on drive down paved road now it has injector issues, seat dry rooted within first year (Texas) dash instrumentation is intermittent as well replacement part are very expensive, mine has the front end loader and 6 foot mower.
Pros: When brand new dependable.
Cons: As it ages it quickly goes down hill. Parts are expensive.
5.00 star(s)
Anonymous Poster
5525_2 Mahindra
Mahindra 5525, definately reliable
Model Year: 2008
I have had this tractor about a year and a half to use on our small horse farm. Uses have been spreading manure, baling hay, clearing snow, running a box blade and using a 8ft pull behind disc, does all jobs with no problems. I cut hay with a NH489 and bale with an old NH66, it will run both machines without breaking a sweat. The only trouble I have is in removing snow, I didn't get the rear tires filled or get wights for them, so getting traction in some of the deeper snow is a big hassle. Thanks goodness for the loader bucket to help me out...
Pros: Very reliable especially in the cold
Cons: Gear tractor so it can get a bit stubborn shifting sometimes, but could need clutch adjustment
5.00 star(s)
Anonymous Poster
5525_2 Mahindra
07 Mahindra 5525 & ML250 loader
Model Year: 2007
The 5525 is a basic two wheel drive full size utility tractor. We had two minor problems with the tractor within the first six months we had it: the injector timing changed and an internal snap ring in a hydraulic valve had not been fully seated and blew out. Both were taken care of promptly by the dealer. I have no complaints about the tractor; with studded ice chains on in winter it does everything I want it to and is a pleasure to operate(I've been using 2wd utility tractors for 35 years).
Pros: Simple,rugged,reliable(so far),handy,easy to operate
Cons: 4F1Rx2 transmission: high range is too fast
Photo Uploads:
Mahindra 5525_2 Owner Pages
View owner pages to see photos, customization and comments about member-owner Mahindra 5525_2s
Mahindra 5525_2 Community Rankings
#547 user rating of 2355 25-50 HP Tractors items
#218 Viewed of 2355 25-50 HP Tractors items
#314 discussed of 2355 25-50 HP Tractors items
#1381 user rating of 19625 items overall
#502 Viewed of 19625 items overall
#743 discussed of 19625 items overall
#14 Ranking of Most-OwnerPages in 19625 items overall
