Kubota BX2200 Reviews
4.00 star(s)
temeku
BX2200 Kubota
Kubota BX2200
Model Year: 2005
Bought the tractor used at just under 200 hours. It has a 211 loader and rear scraper. I've put about 100 hours on it and the engine and driveline have run very well (mostly). I have a small property of 1 acre but it has been very useful and met most all my needs. I had a B7500 and it was a great tractor but I needed the maneuvering of the smaller tractor in tight spaces. On the good side....maneuverability and pretty much reliable. I really like what it can do for my needs. I have a few changes in terrain and the 4wd is an absolute must. Rarely can I get by without it. On the bad side, I am amazed at how often the hydraulic lines burst or fail. I've replaced at least 5 of them. Often at inopportune times. I can generally get them replaced within the hour at a local Napa auto parts store. But it's still a hassle. I also feel the loader hardware tends to require frequent checks for loose screws. The loader bushings had significant wear (upon purchase) which seems excessive for only 200 hours. One other problem was the previous owner ran biodiesel and it must have coagulated in the fuel system. I had to clean that out and new filters. Then I had a really rare problem when it wouldn't start. Long story short, I determined the biodiesel must have caused some sort of sticky gunk in the fuel injection system. The weather was cold (below 50F) so I took a hair dryer and warmed the injector. It started after 20 minutes of heating. I added some fuel system cleaner and haven't had a problem since. As per the manufacturer, do not use biodiesel. It might work under the right conditions and right type fuel, but for me it's not worth the potential problems. I also feel the engine cover vibrates excessively at lower rpms which is a little annoying at times. Another thing that I could use is an adjustable side angle (not up and down) on rear scraper. I have to adjust the angle manually, which is limited, but better than nothing, so it takes time to dial it in for a give situation. Also, the scraper tends to drag easily when it's on the tractor and while maneuvering over slight changes in incline. It can be a real problem, especially when backing. I don't know if there is a better tractor out there but when it's working, it works very well for my needs and I can't imagine wanting anything else. Just wish the hydraulic lines were more reliable. I think there are always trade-offs and no question it get's the job done.
Pros: manuevrability, 4 wd, engine runs great, very economical
Cons: hydraulic lines break too often, front loader hardware loosens up,
