3RRL
Super Member
- Joined
- Oct 20, 2005
- Messages
- 6,931
- Tractor
- 55HP 4WD KAMA 554 and 4 x 4 Jinma 284
Loretta finally got around to changing her injector pump oil on her 2008 Jinma 284. It is a good thing to check it frequently and change it once a year or sooner if you wish. Keeps your injector pump in good working order.
Some reminders on how to do it. Refer to the photos below and use a level surface to park the tractor on.
First, remove the fill/breather cap on the top rear of the injector pump. It needs a 13mm open end wrench. I didn't take any photos of it (duh), but it looks like/is a miniature breather cap. It's right behind the accelerator linkage. Be sure to rinse it out with diesel or gas and dry it and don't lose the copper washer(s).
Then get a container to drain the oil out and remove the bottom drain plug where shown in the photo (13mm also). What we did is measure the amount of oil that came out for a reference, since some pumps take different amounts of oil.
After draining, put the drain plug back in and tighten.
Then remove the Bleeder cap with a 12mm wrench or screw driver (it has a slot in the bolt). Some have a little rubber plug on the end. I took hers off to check it out. It is a small banjo type fitting like shown in the pictures below. Leave it out for the time being, as the oil you pour in will go in a little easier.
Then using the amount of oil that came out as a guide, pour that amount of new oil into a small container that you can pour into the fill hole (photo above). We used 30w compressor oil, but you can use motor oil if you prefer. A lot of guys use the same as their engine oil. Anyway, after you get that oil in, screw the bleeder plug back in, but do not tighten yet and leave the rubber cap off. Wait a couple minutes to see it starts dripping from it.
If it does, wait about 15 minutes or so before tightening it up and put on the rubber cap. If it does not, add about 1 oz of oil at a time and wait for it to drip. After it stops dripping, that means the pump is filled to the right level. Then you can tighten it up and put the rubber cap back on. Also reinstall the breather fill cap and tighten it up. We found her Jinma took about 8oz or so.
That's all there is to that. Check the level frequently and change it at least once a year after that.
