How much ditching would cause buy choice?
   / How much ditching would cause buy choice? #1
wawajake
Canada
Kubota BX2660 , Kubota RTV X1100C
How feasible is ditching with a front bucket versus buying a backhoe attachment.
I am in market to buy a compact tractor up here in Canada.
My soil conditions is primarily clay with a few rocks.
I have 40 acres but 30 is bush and the remaining ten acres climbs up a hill behind my house, so I see using the tractor for typical snowplowing of 300 ft driveway and glorified wheelbarrow etc etc, but I also see myself needing to improve ditches / swales to improve drainage off the hill to run spring runoff away from my house.
Will a 4 ft bucket on a maybe 25 hp compact tractor still be able to cut into the clay with downward force and then I would just do 4ft of ditch at a time to depth of 2 or 3 feet , with maybe a ditch 3 or 4 feet wide.
Or am I expecting too much for front bucket and should look for tractor with a backhoe attachment ?
A new Kubota or Deere with front bucket and backhoe will run me $25,000 grand for small compact model I bet. So doing without backhoe might keep purchase under $20,000.
Any thoughts on ditching with front bucket?
jake
   / How much ditching would cause buy choice? #2
jake
Front end loaders are meant for scooping loose stuff (dirt, gravel, sand, etc). The FEL bucket is not a particularly good digging tool. It helps to add a tooth bar to the bucket, but this only gets you part of the way to solving your ditching problem.
A lot of folks use a box blade to cut ditches and swales. Some have top n tilt mechanisms to make tilting the blade sideways easier. You can cut ditches and swales with this implement, but it takes a fair amount of practice to become proficient.
My preferred way to handle ditching and swale building is to use a plow (middle buster or moldboard) to loosen the soil. Then use the FEL bucket to scoop up the loose stuff and contour the ground.
   / How much ditching would cause buy choice? #3
A box blade is good for a swale, for a true ditch a backhoe is better.
If you can lower the FEL enough, it is good for cleaning out existing ditches, but I wouldn't try to make a new one with it.
   / How much ditching would cause buy choice? #4
you'll be happy to know a JD 2305 TLB is well under $20k US.
   / How much ditching would cause buy choice? #5
Not quite 25 hp but a Kubota BX24 is under 20k also. Maybe around 17k and it comes with a loader and a hoe. For under 20k you could get one with a MMM(mid mount mower) and a scraper blade for the rear(clears snow pretty good). -Matt
Thanks for replies folks, I don't forsee needing it regularily for snow because I already have a ATV with 60 inch plow that worked quite well our first winter (2008)
The areas that need the most ditching already have ditches that have filled in somewhat . So I have roughly 200 yards of that .............and then some new ditching/swaling I could do that would just require one or two feet deep . I also already have a 48 inch Husqavarna lawn tractor so don't need tractor to do my two acres of lawn cutting. I will also use tractor to improve/maintain some ATV trails I use to retrieve firewood from my 30 acre woodlot.
We have one dealer here that sells Kubota and John Deere.
The only other dealer is 60 miles away and he sells the chinese type FUTON. (Jima ?). I can get a 24 hp 4WD FUTON with FEL and backhoe for roughly $17,000.
I am going to Kubota/JD dealer on friday , but I would be very supriosed if in Canada I can get similar equiped JD or KUbota for under $20,000, . My budget is actually $15,000 but flexible.....so thats why I figure I should reconsider backhoe need. But I also forsee doing ditching every year and I work all week so renting and getting it all done in a few days is not option.
I might need to look used if my local dealer cannot meet my budget. I do get the impression here from you folks that a decent dealer is most important and I hear good things about the Kuboat/ JD dealer, and not so much about Futon dealer further away.
jake
   / How much ditching would cause buy choice? #7
If you don’t mind the ditches wide enough for your tractor to ride the middle of the ditch I think it is doable. A box blade or tiller to loosen up the soil followed by the tractor loader to clean up the spoils will work. With a rear blade that can tilt you can taper the edges to let your mower traverse the ditch. After the first time regular cleaning will not be bad with the loader if done often enough. If the first time is too much renting a mini excavator for a weekend can get a lot of digging done for much less than the cost of a backhoe.
Oh ya, welcome to the forum Jake.
MarkV
Thanks Mark ...and all......... I have been gleaning the numerous forums here and also found one that mentioned a three point hitch attachment implement called a "middle buster" its a 14" furrower. like Flusher mentioned above . I can see being able to straddle any existing ditches and running this implement one or two times down the middle of ditch (hopefully not hitting too many rocks or roots) and then using the front end loader to clean it up. I don't mow these ditches anyway.
If you folks think that is doable then i think I will buy a tractor without the backhoe and look at getting pull behind attachments instead like the "middle buster" or " box blade". Those are probably useful anyway and if don't work as well as I like then I could rent or see if the wife will stretch the budget next year to add a backhoe.
Now maybe i can afford a Kubota or John Deere compact 2305 . my check book is ready
thanks I will let you know how it turns out and I suspect I will be regular here.
   / How much ditching would cause buy choice? #9
Okay, let me see if I have this correct: You want to dig (or at least clean out) ditches 2 to 3 feet deep, 3 to 4 feet wide, and 600 feet long? Using the lower of your numbers, that comes out to 133 cu yds of material to move, or about eleven dump truck loads if that makes it any eaiser to picture.
Plenty of seat time.
   / How much ditching would cause buy choice? #10
Jake, just don't underestimate the amount of things you will find to do with a tractor. You have 40 acres and sometimes buying a paint brush to paint a house makes sense until you have tried to paint a house with a paint brush only.
MarkV
Rowdius , first off the ditching needs (being one of many jobs I forsee using tractor for) is primarily just improving ditches already there, but they overflow in spring .
They are 3 feet wide where they meet level ground and maybe 2 feet deep at lowest point of typical crosssection of the ditch . I want to get them to 3 feet deep generally.
So at most I am making them one feet deeper. So by my math I am probably removing one cubic foot of earth for every linear foot of ditch . Ideally I would put that earth on low side of ditches to make that side of ditch higher than the slope side. (the ditches traverse the hill to intercept spring runoff)
I expect to also maybe add a few swales other places in my acreage. I will admit to being a rookie but did spend many a summer as a student 20 years ago on a shovel and rake working beside a backhoe operator , so know the general principles on ditches and swales . I don't know the pull behind implements that can replace backhoe work when used in conjunction with a front end loader implement on a CUT . So that is what I am here for . I hope that makes it clearer.
jake
   / How much ditching would cause buy choice? #12
Hi,
I would also look very closely at a KIOTI CK20. Currently KIOTI is offering a free loader deal for this tractor in Canada as well. That is hard to beat. I just bought a KIOTI CK27HST in Nova Scotia with FEL and Backhoe. I'm very happy with my purchase. I also looked at JD and KUBOTA which were way more expensive.
Jochen
   / How much ditching would cause buy choice? #13
MarkV
I like that.
I'd buy the tractor with a backhoe. My last tractor with FEL and backhoe cost me roughly $275 a year for 20 years to own. Resale value on these tractors is very good.
   / How much ditching would cause buy choice? #14
I agree with zumsel, the Kioti CK20 is a **** of a little tractor. With a tooth bar and box blade you should be able to maintain your ditches with little or no problems. If you go with the Kioti, make sure you get your tires loaded, it makes a difference working with the loader.
Eddie
   / How much ditching would cause buy choice? #15
I have 40 acres but 30 is bush and the remaining ten acres climbs up a hill behind my house, so I see using the tractor for typical snowplowing of 300 ft driveway and glorified wheelbarrow etc ebut I also see myself needing to improve ditches / swales to improve drainage off the hill to run spring runoff away from my house.
jake
A feel is not ideal for diging ditches .
hard on the loader arms bucket and tractor.
BH works a lot better.
My BX23 Tractor loader and BH with 60'' mower was 15500
back in 2004.
You can get a tractor and back hoe and beat $20000.
   / How much ditching would cause buy choice? #17
I use A BX1500 with a front blade and a rear tiller and or A BX24 with A FEL and A BH.
I am going to the local dealer on Friday to see if a new BX24 (with FEL and BH) is feasible, or the equivalent in John Deere he carries too. I also have a line on a almost new BX 24 for $17,000 on the others side of the province , but am worried if any liens on it and if my local dealer will still treat me right if I need service on a used one I did not buy from him.
I will see how he treats me on his sales pitch tommorrow.
jake
   / How much ditching would cause buy choice? #19
I think you could probably walk out the door with a Kubota B2320 or B2620 with FEL and Hoe for just under 20k as well if you shop carefully and have a negotiable dealer...
SKID STEER ATTACHMENT HAMMER (A58214)
SKID STEER...
3410 (A47477)
3410 (A47477)
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
