BX rear weight
   / BX rear weight #1
miker2702
east tenn
bx2200
someone had a post and picture of a plastic garbage
can weight filled with concrete. i can not remember
if it was here? do it yourself? attachments? can
anyone remember where??
   / BX rear weight #2
Like this?
I made it myself. Picked up a cheap garbage can, a drawbar, some flat stock metal, and a few pins.
   / BX rear weight #3
The only thing I don't like about it you didn't paint the can Orange, HAHAHAHAHAHAHA!
   / BX rear weight
thanks zick great idea i have some left over golf tubes from a
rod tip divider in my boat if i can get them in there it might make
a tool holder also.
   / BX rear weight #8
Like this?
Guessing this makes a big difference when using your front end loader?? Also how is the tip factor when driving off camber?? Thinking of doing something similar....;)
   / BX rear weight #9
Big difference when maxing out the loader! Usually my rear comes off the ground long before I get the max weight in the bucket, but w/ the ballast that problem is gone. :D
Not sure about the tip factor as my land is pretty flat.
2001 Ford F150 (A50121)
2001 Ford F150...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
2022 John Deere 8RX 410 Tractor (A53342)
2022 John Deere...
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
2023 John Deere 324G Skid Steer (A53342)
2023 John Deere...
