BX rear weight
/ BX rear weight #1
miker2702
east tenn
bx2200
someone had a post and picture of a plastic garbage
can weight filled with concrete. i can not remember
if it was here? do it yourself? attachments? can
anyone remember where??
/ BX rear weight #2
Like this?
I made it myself. Picked up a cheap garbage can, a drawbar, some flat stock metal, and a few pins.
/ BX rear weight #3
The only thing I don't like about it you didn't paint the can Orange, HAHAHAHAHAHAHA!
/ BX rear weight
thanks zick great idea i have some left over golf tubes from a
rod tip divider in my boat if i can get them in there it might make
a tool holder also.
/ BX rear weight #8
Like this?
Guessing this makes a big difference when using your front end loader?? Also how is the tip factor when driving off camber?? Thinking of doing something similar....;)
/ BX rear weight #9
Big difference when maxing out the loader! Usually my rear comes off the ground long before I get the max weight in the bucket, but w/ the ballast that problem is gone. :D
Not sure about the tip factor as my land is pretty flat.
/ BX rear weight #13
On my little BX1500, I have a heavy duty 4' Box Blade that works very well for a counterbalance. It works better as a counterbalance than it does a box blade. The turf tires can't get enough traction to scrape much... :rolleyes:
