BX rear weight
/ BX rear weight #1
miker2702
east tenn
bx2200
someone had a post and picture of a plastic garbage
can weight filled with concrete. i can not remember
if it was here? do it yourself? attachments? can
anyone remember where??
/ BX rear weight #2
Like this?
I made it myself. Picked up a cheap garbage can, a drawbar, some flat stock metal, and a few pins.
/ BX rear weight #3
The only thing I don't like about it you didn't paint the can Orange, HAHAHAHAHAHAHA!
/ BX rear weight
thanks zick great idea i have some left over golf tubes from a
rod tip divider in my boat if i can get them in there it might make
a tool holder also.
/ BX rear weight #8
Like this?
Guessing this makes a big difference when using your front end loader?? Also how is the tip factor when driving off camber?? Thinking of doing something similar....;)
/ BX rear weight #9
Big difference when maxing out the loader! Usually my rear comes off the ground long before I get the max weight in the bucket, but w/ the ballast that problem is gone. :D
Not sure about the tip factor as my land is pretty flat.
/ BX rear weight #13
On my little BX1500, I have a heavy duty 4' Box Blade that works very well for a counterbalance. It works better as a counterbalance than it does a box blade. The turf tires can't get enough traction to scrape much... :rolleyes:
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
2010 FORD F750 BUCKET TRUCK (A65054)
2010 FORD F750...
2025 MACK GRANITE GR64F DUMP TRUCK (A63276)
2025 MACK GRANITE...
UNUSED 2023 JCB S3246E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
2019 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A64556)
2019 Peterbilt 579...
2016 CATERPILLAR 926M WHEEL LOADER (A65053)
2016 CATERPILLAR...
