FEl raise and curl
/ FEl raise and curl #1
Deerlope
Northern, New York
Kubota L3830 03: RTV 900
I have done a few searches and still I do not have a clear answer. Why on a Kubota M-5040 can I not raise the FEL and curl back at the same time? My dealer said it is for safety reasons and he does not know how to change it. He stated that an inexpencerenced operator could be catapulted from the tractor. If I go into a pile of loose gravel at ground level I have this problem.
/ FEl raise and curl #2
That's weird. Then why is that dual function enabled on my smaller L4740?
/ FEl raise and curl #3
My BX1850 has the same limitation. Interesting that it applies to an M series tractor too. Anyway, my understanding on why Kubota limits the FEL functions is due to limited hydraulic pressure, at least for the BX series. Curling the bucket or raising the FEL both take a lot of pressure if you're working against a heavy load. Allowing you to divert fluid to both the boom and curl cylinders at the same time would result in less than ideal lifting capacity. To my knowledge, it's not a safety issue.
/ FEl raise and curl #4
I can raise and curl with my B1750 but you should go into a bank and slowly raise, bucket level and creep forward. At some point you have to curl to secure the load. You can still curl when the buckets full right? If so just stop raising.
/ FEl raise and curl #5
Can't do it on my L4240 either. It's stated in the manual that you can not do this, but no reason why not....
/ FEl raise and curl #6
I can do both at the same time on my B3030. I use it mostly to reposition the bucket to level while lowering the bucket at the same time after dumping. It saves a little bit of time that way. I also use it when lifting a load that needs to stay balanced in the bucket as it is being raised. I can't think of anything unsafe about it. It does slow down the lifting and lowering somewhat as the fluid is diverted to both functions. I would be disappointed now if a larger tractor did not have the same capability.
/ FEl raise and curl #7
The limitation is only when raising the boom and curling the bucket back at the same time. My bx 23 has this limitation and mentions it in the manual.
They say it's because of not enough volume to run both when lifting something. I have wondered if it is to prevent coupling of the two sets of cylinders on the same hydraulic circuit and causing unintended movement.
Maybe one of the hydraulics experts here will reply.
/ FEl raise and curl #8
I get it now. What I described is not the same thing. I'll have to try raising and curling at the same time. I normally go into a pile and if it won't lift I might try to curl to see if that breaks it loose. However, I don't think I have ever tried to do both at the same time. It might work if the load is not heavy, but probably not when the load is at or beyond lift capacity, which is understandable.
/ FEl raise and curl #11
The LA853 loader on my L5030 operates with dual function until you hit the limit of either cylinder. At that point, both cylinders stop, even if the other one isn't at the limit. From what I understand, that's common in lower end 4-way joystick valves vs. the stuff you find in pure, construction grade equipment.
It would seem odd to me that the L-series has a dual function feature, but not the M-series...
/ FEl raise and curl #12
Well...mine will too but with very little power.
If you go into a pile of soil it and try to curl and lift at the same time nothing happens, switch to just lift and it will raise it up.
/ FEl raise and curl #14
This deserves a better explanation that whats showing up here.
The hydraulic fluid will go the path of least resistance. Its possible to do multiple functions if your a good enough operator to open each circuit just enough to bring relative equal pressure to each circuit. This is typically more difficult on the smaller tractors than it is the larger ones. When in a pile of dirt, you should curl, then lift so your pushing 100% of the pressure into the curl cylinders. If your out of a pile and trying to keep a load level curling while moving up or down should be very possible for most operators.
Whatever dealer may have said its some safty feature does not know what they are talking about.
2015 Chevrolet Tahoe SUV (A64557)
2015 Chevrolet...
2019 FREIGHTLINER M2 4X2 S/A NON 26FT NON CDL BOX TRUCK (A67148)
2019 FREIGHTLINER...
Barrel (A64557)
Barrel (A64557)
1996 Polar DOT 407 Single Comp Insulated Diesel Trailer (A64194)
1996 Polar DOT 407...
2019 Kenworth T880 Tri-Axle Dump Truck (A61573)
2019 Kenworth T880...
2013 Mack CXU613 T/A Day Cab Truck Tractor (A64556)
2013 Mack CXU613...
