Once again...BX24 Weight
/ Once again...BX24 Weight #1
Tractor Factor
Gold Member
Outer New York
Kubota BX25, BX1860
Hi all, I've been reading here for a while and decided to sign up as I'm close to pulling the trigger on a BX24. The thread on weight from a few months ago seemed to toggle back and forth between about 2300# and 2800# for the tractor, loader and backhoe. I tended to lean toward those who said the latter, as 2300 just seemed too light for that combination. But today I had two different local dealers tell me that the weight was about 2300. :confused:?:confused:? Anyone really know?
/ Once again...BX24 Weight #2
All the weights are in their manuals.
Well, presumably, that's where the two dealers I spoke with got their misinformation from. I see elsewhere that the backhoe is 617#...so, 617 and 1542 is 2159. Now, what does the loader weigh?
Thanks. I guess that's getting up to a total of about 2666# so far, which seems to be close to reality.
I have to tow it 150+ miles and the rental will have to be a single axle with a total load capacity of 2500#. I've read a number of towing threads here and understand the potential problems, so I think I'll put the front end in my pickup bed which would leave about 2100# in the tractor and backhoe chained to the trailer. And, I'll take it sloooowww...:)
/ Once again...BX24 Weight #6
Here is the compilation of info i got from my BX24 owner manaul.
Keep in mind this is printed into, not actual info. I have yet taken my tractor on the trailer to the truck scales to compare this info in real life.
BX24 weight info
BX24 1520 lbs
Mower 250 lbs
Loader 375 lbs
Bucket 132 lbs
Back hoe 280 lbs
Total
Bx24+mower=1770lbs
Bx24+loader=2027lbs
BX24+loader+backhoe=2307lbs
BX24+loader+backhoe+mower=2557lbs=1.5 ton
Loader can lift 235 lbs
3 pt hitch can lift 1210 lbs
Lower hitch tongue weight = 550lb
Lower hitch tow 1765lbs trailer weight
Wow, thanks for that info, radioman. That number seems really low for the backhoe...I thought it weighed a lot more than that. That lowers the overall weight quite a bit. Hey, Ontario! You're right in my backyard (near Geneseo).
/ Once again...BX24 Weight #8
There is no way that the backhoe only weighs 280 lbs.
I towed my BX24 50 miles on a single axle 12 ft trailer(no trailer brakes) with the 60" mower and a 5ft woods back blade. I backed the tractor up on the trailer 'cause most of the weight is in the rear. I wouldn't put the loader in the back of the truck to tow if it was me. That leaves too much weight on just the rear of the tractor and it'll be very bouncy towing down the road. Just lift the loader over the ramps and let it rest on the ramps. Let the hoe hang over the front of the trailer a little and put the pins in the hoe so it doesn't move around. Even though the manual states to let the hoe rest on the trailer it will bounce around a lot if not chained down. Put it in four wheel drive and set the brake. Chain it down and stop to check your load a few times along the way. Leave lots of stopping room and make turns easy. Down shifting on hills ain't a bad idea either. Your gonna love that tractor.
I towed my BX24 50 miles on a single axle 12 ft trailer(no trailer brakes) with the 60" mower and a 5ft woods back blade....
Thank you so much for the benefit of your experience. It gives me encouragement for the trip. Nice dog, btw.
/ Once again...BX24 Weight #10
DOH!! :eek: i looked it up again and it relized that it was 280 kilos. backhoe is 617 lbs. here is the corrects specs.
BX24 weight info
BX24 1520 lbs
Mower 250 lbs
Loader 375 lbs
Bucket 132 lbs
Back hoe 617 lbs
Total
Bx24+mower=1770lbs
Bx24+loader=2027lbs
BX24+loader+backhoe=2644lbs
BX24+loader+backhoe+mower=2894lbs=2.9 tons
/ Once again...BX24 Weight #11
2894 lbs is not even 1.5 Ton. Thats a regular USA ton, not a metric ton. One ton = 2000 lbs.
And the tractor is a wonderful piece to have around!
Craig
/ Once again...BX24 Weight #12
Yes you are correct.Thanks for the correction. Meanwhile, Ill be burying my head in the ground from 2 embarrassments tonight so far.:eek:
/ Once again...BX24 Weight #14
Since most of the advise you give is pretty good we'll forgive you this thread:D.
/ Once again...BX24 Weight #15
FWIW - I second radiomans corrected response - I had done a similar calculation when I firt got the BX
Tractor 1542
BH 617
FEL 507
MMM 189 (54" deck)
2855
Dealer delivered mine with filled tires - so take that into account as well
/ Once again...BX24 Weight #16
All those weights listed are probably DRY weights too....add the 4 gallons plus* of hydro fluid, the gallon or so of engine oil and the fuel and you are probably dang close to the 2800 figure for a BX24 TLB.
* yeah the change volume is 3.1 gallons but remember some is in all the hoses and cylinders that stays in;)
/ Once again...BX24 Weight #18
My BX 23 with Fel BH and MMM weighs 2467 pounds.
/ Once again...BX24 Weight #19
BH is right about 600 pounds.
/ Once again...BX24 Weight #20
I have to tow it 150+ miles...rental will have to be a single axle with a total load capacity of 2500#. ...front end in my pickup bed which would leave about 2100# in the tractor and backhoe chained to the trailer.
By "front end", I hope you mean putting the complete FEL assembly in the bed and not simply resting the bucket in the bed while towing. I'd be a little curious on how you are going to get it in the bed.
Regarding the trailer capacity, remember that you have to take the weight of the trailer out of the capacity as well. I've personally towed my tractor in a 5' x 10' 3,500# capacity trailer (1,000# more than the trailer you're talking about) and I have to say that I didn't feel it was safe but for 5 mile trips at 35 MPH. There are many reasons for this not being safe, but the two biggest factors are the inadequate sidewall stiffness and the lack of brakes. I beg of you not to tow with this rental trailer you spoke of. Beg. Hands and knees.
Put another way: I would absolutely, positively, under no circumstances whatsoever, feel comfortable with my $20,000 machine in a rented trailer with a capacity of 2,500#. No way, no how. Just too small.
If at all possible, I would contemplate a trailer with your purchase. The absolute bare minimum trailer with one of these machines is a 6' x 14' landscape-style trailer with brakes on one axle and a 7,000# capacity. You could probably get a new one of these in the $1,400 range. The preferable trailer would be 6' or 7' x 16' flatbed with brakes on both axles.
I purchased my 10,000# trailer for $2,500 and absolutely love it. I have put over 6,000# of material on it several times now (6 times, to be exact) and can "power un-load" all day long. I just re-did someones driveway for them yesterday. I dropped the tractor off, un-chaining it in about 3 minutes, went to the quarry and picked up 3 tons of stone, unloaded and spread the 3 tons of stone in about 20 minutes, then spent 30 minutes dressing the driveway with the box blade, then loaded the tractor, properly chaining it down in under 5 minutes. The whole thing, including picking up the stone, took about 2 hours. If I wasn't able to unload the stone with my tractor, I'd spend 2 backbreaking hours just getting the stone off the trailer.
As a bonus, I've saved myself over $500 (conservatively) in delivery charges. Only once could I have saved by a larger haul (my first project called for 6 tons of stone)...all the others would have been seperate deliveries. I will probably have the trailer "paid off" by saving myself delivery charges in 3 or 4 years of use.
Bobcat T66 (A60462)
Bobcat T66 (A60462)
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
(1) 300 GALLON POLY TOTE W/CAGE (A60432)
(1) 300 GALLON...
2014 Lincoln MKX SUV (A59231)
2014 Lincoln MKX...
SKID STEER ATTACHMENT SIFT BUCKET (A58214)
SKID STEER...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A59905)
2018 FREIGHTLINER...
