Once again...BX24 Weight
   / Once again...BX24 Weight #1
Tractor Factor
Outer New York
Kubota BX25, BX1860
Hi all, I've been reading here for a while and decided to sign up as I'm close to pulling the trigger on a BX24. The thread on weight from a few months ago seemed to toggle back and forth between about 2300# and 2800# for the tractor, loader and backhoe. I tended to lean toward those who said the latter, as 2300 just seemed too light for that combination. But today I had two different local dealers tell me that the weight was about 2300. :confused:?:confused:? Anyone really know?
   / Once again...BX24 Weight #2
All the weights are in their manuals.
Well, presumably, that's where the two dealers I spoke with got their misinformation from. I see elsewhere that the backhoe is 617#...so, 617 and 1542 is 2159. Now, what does the loader weigh?
   / Once again...BX24 Weight #4
Thanks. I guess that's getting up to a total of about 2666# so far, which seems to be close to reality.
I have to tow it 150+ miles and the rental will have to be a single axle with a total load capacity of 2500#. I've read a number of towing threads here and understand the potential problems, so I think I'll put the front end in my pickup bed which would leave about 2100# in the tractor and backhoe chained to the trailer. And, I'll take it sloooowww...:)
   / Once again...BX24 Weight #6
Here is the compilation of info i got from my BX24 owner manaul.
Keep in mind this is printed into, not actual info. I have yet taken my tractor on the trailer to the truck scales to compare this info in real life.
BX24 weight info
BX24 1520 lbs
Mower 250 lbs
Loader 375 lbs
Bucket 132 lbs
Back hoe 280 lbs
Total
Bx24+mower=1770lbs
Bx24+loader=2027lbs
BX24+loader+backhoe=2307lbs
BX24+loader+backhoe+mower=2557lbs=1.5 ton
Loader can lift 235 lbs
3 pt hitch can lift 1210 lbs
Lower hitch tongue weight = 550lb
Lower hitch tow 1765lbs trailer weight
Wow, thanks for that info, radioman. That number seems really low for the backhoe...I thought it weighed a lot more than that. That lowers the overall weight quite a bit. Hey, Ontario! You're right in my backyard (near Geneseo).
   / Once again...BX24 Weight #8
There is no way that the backhoe only weighs 280 lbs.
I towed my BX24 50 miles on a single axle 12 ft trailer(no trailer brakes) with the 60" mower and a 5ft woods back blade. I backed the tractor up on the trailer 'cause most of the weight is in the rear. I wouldn't put the loader in the back of the truck to tow if it was me. That leaves too much weight on just the rear of the tractor and it'll be very bouncy towing down the road. Just lift the loader over the ramps and let it rest on the ramps. Let the hoe hang over the front of the trailer a little and put the pins in the hoe so it doesn't move around. Even though the manual states to let the hoe rest on the trailer it will bounce around a lot if not chained down. Put it in four wheel drive and set the brake. Chain it down and stop to check your load a few times along the way. Leave lots of stopping room and make turns easy. Down shifting on hills ain't a bad idea either. Your gonna love that tractor.
I towed my BX24 50 miles on a single axle 12 ft trailer(no trailer brakes) with the 60" mower and a 5ft woods back blade....
Thank you so much for the benefit of your experience. It gives me encouragement for the trip. Nice dog, btw.
   / Once again...BX24 Weight #10
DOH!! :eek: i looked it up again and it relized that it was 280 kilos. backhoe is 617 lbs. here is the corrects specs.
BX24 weight info
BX24 1520 lbs
Mower 250 lbs
Loader 375 lbs
Bucket 132 lbs
Back hoe 617 lbs
Total
Bx24+mower=1770lbs
Bx24+loader=2027lbs
BX24+loader+backhoe=2644lbs
BX24+loader+backhoe+mower=2894lbs=2.9 tons
New 4ft Bush Hog Rotary Cutter (A44391)
New 4ft Bush Hog...
Chemical Containers 500 Gallon Chemical Injection Trailer (A44571)
Chemical...
2015 Ford Taurus Sedan (A44572)
2015 Ford Taurus...
EZ-GO Gas Powered Golf Cart (A44391)
EZ-GO Gas Powered...
1671 (A44572)
1671 (A44572)
1995 TOYOTA LAND CRUISER SUV (A43004)
1995 TOYOTA LAND...
