Rust Penetrant Recomendations
   / Rust Penetrant Recomendations #11
PB Blaster, saved my you know what,
more than once.
Wouldn't be without it.
elad
Thanks for the opinions guys! Yes its definately a Ford / Chevy or Deere / Kubota debate. ;)
Thats why i was hoping for someone to know a scientific, unbiased study. Ive read the study by Home Shop Machinist JJ mentioned. Its the famous ATF/Acetone test published all over the net. Considering hot hotly this topic gets debated I was hoping to find some confirmation of those results somewheres.
All and all it was a frustrating day. I went to Zep to get a couple cans of their penetrating fluid and a gallon of hand cleaner, only to find that their new policy requires an order of at least $150 :mad: Im not a Business major but it doesnt make sense to pass up a $60 sale. The salesman told me it has cost them most of their counter sales and some of their small commercial customers:mad: Oh well.
So I ended up at the GM dealer and bought some of their Penetrant based on Sackett2's recomendation. Soaked the manifolds tonight, found a couple broken studs:rolleyes:. I have to finish springs on a Toyota then the Ford goes into the shop tomorrow. Cant wait to get started...Not.
Dealer estimate was at least $700 for this job. After looking at it i can see why! No idea what im gonna charge. It will depend alot on how Pi33ed off i get:D
Ill post my opinions on the GM stuff when Im done. Maybe I found a replacement to my usual goto Kroil.
   / Rust Penetrant Recomendations #13
I agree with the small amount of heat, oil, and time. Heating not only causes the nut to expand but also causes the gases trapped in the rust to expand and push out. Directly after heating drench the area with penatrating oil to cool materials. This cooling will cause a vacuume in between the threads and penetrating oil will be drawn into the threads. Repeating these steps also helps tremendously. After following these steps several times, use an air chisel or a long chisel and hammer to turn the nut by hitting it on the edge at an angle that will force it to turn. I worked at an exhaust shop for a while in my automotive career and learned a lot of tricks from some experienced old timers, and this is one of the best and most successful ones I've learned for freeing rusted nuts. Penetrating oil brand is less important than technique. Good luck.
Interesting points. Yeah i had planned on taking the torch to it first. Id like to think i could get in there with the chisel, but looking at it i dont think i got the room. The f150 is pretty tight. Definitely not designed by a mechanic. I think im going to have to take the inner fenders out anyways to make room to work. Im gonna need all the luck i can get :D
   / Rust Penetrant Recomendations #16
That is how I usually charge for work:D:D
   / Rust Penetrant Recomendations #17
There have been many good penetrating sprays suggested here but for rusty items like exhaust system components I think you will find there are few things that work as well as a propane torch and and paraffin canning wax. Heat the bolts or nuts with the torch and press the bar of wax against it. The rust acts as a wick sucking up the melting wax. A old now retired mechanic taught that to me years ago at a dealership I worked at. Works great on rusted bolts stuck in highly oxidized aluminum parts like water necks and water pumps.
   / Rust Penetrant Recomendations #18
I have had good luck with Fluid Film, the Deere dealers around here carry it.
   / Rust Penetrant Recomendations #19
I've seen Zep 45 break loose nut,bolts and studs on heavy equipment that I thought were impossible to get loose. Maybe try a little heat and spray on the Zep so it will work its way down into the threaded hole.
Sincerely, Dirt
   / Rust Penetrant Recomendations #20
I took a Yanmar diesel head to a machine shop for a repair. They said it was unrepairable because they ruined the injector trying to press it out. I took it home and sprayed Pb Blaster on the injector every morning as I left for work. After several days one tap and it hit the floor. I have many more tails of the amazing PB. As said, time is a big factor.
In the for what it is worth factor I also like PB blaster it has worked well for me.
2025 CFG Industrial QK20R Mini Excavator (A59228)
2025 CFG...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
John Deere 4044M (A60462)
John Deere 4044M...
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
2017 FORD F-450 XL BUCKET TRUCK (A58375)
2017 FORD F-450 XL...
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
