Changing filter?
   / Changing filter? #1
NIXON
West Sunbury ,Pa.
L3130 hst
I've got to change the Hydro,and trans filters . Can I do it without draining the Sudt from the tractor ?
   / Changing filter? #2
I changed the hydro and trans filters on my L3240HST without draining first. Used less than 1 gallon SUDT to "top off" after change. Tractor was parked on flat surface during filter change.
   / Changing filter? #3
Just wondering, Why change the filters only?
   / Changing filter? #4
Because transmission/hydraulic fluid does not become contaminated with combustion by products like engine oil does.
By the way, I bounght a gallon of UDT Monday and it was $22. OUCH
   / Changing filter? #5
I replaced the filter on my B2320 for the 50 service without draining it. I just took the old one off and put the new one as quickly as possible. I then topped it off. This is how my dealer told me they do it.
   / Changing filter? #6
The only advice I could offer would be to flip the tractor upside down, change the filters quickly and then right side up the beast. :eek:
Nix, what I really wanted to say, on this 'Veterans Day' was to give you a shout-out and say 'thank you' to you and your military family for their service to our Country. ....and thanks to all the military veterans out there for your service to our Country, the good ole USA!
Don
   / Changing filter? #7
1* I just took the old one off and put the new one as quickly as possible. I then topped it off.
2* This is how my dealer told me they do it.
1&2* Not a good way to do the 50 hour service.
   / Changing filter? #8
I agree Mr Brown unless the owners manual says different. I changed out all my fluids and filters at 50 hours as per the manual and which I thought was the most critical with all the metal shavings in the break in period.
   / Changing filter? #10
The manual for my 5030 says to change the filters and fluid for the 50 hour service including the front axle fluid. The manual for my 5740 which is a year newer says to change the filters only at 50 hours and leave the front axle fluid until 400 hours.
2002 International 9200i Truck (A52128)
2002 International...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
Case 830 Tractor (A50514)
Case 830 Tractor...
2013 LONE STAR TRAILER MFG. (A50854)
2013 LONE STAR...
Roose Hog Cart (A50515)
Roose Hog Cart...
