Salesman said to only to use 4wd....
   / Salesman said to only to use 4wd.... #41
With my B1750 I've found that in 2WD the front wheels tear up the turf while turning sharp corners. The B1750 has the bi-spead turn where in 4WD the front wheels turn faster during a tight turn, pulling the front end around and this seems to protect the grass fairly well so in my case leaving the tractor in 4WD is preferable - even on flat ground.
As I understood it the bi-speed turn thing is a way of adding more lead to the front to allow for it being on a wider arc.
   / Salesman said to only to use 4wd.... #42
I leave my B7800 in 4WD all the time but I don't drive it on pavement at all.
Sadly, it seems that my truck has been in 4H most of the time since winter came early on Nov 9 this year:eek:
   / Salesman said to only to use 4wd.... #43
Tried 2wd drive when first got tractor to compare to 4wd then left it in 4wd since. only on gravel or snow so see no problem.
   / Salesman said to only to use 4wd.... #44
Who say it isn't need 24/7?
I do. The problem is...-without guaranteed circumspectness you get caught in a dangerous situation; needing it but unable to engage. 2wd is usually more efficient tho - the front tires last longer and the tractor usually turns better and with less ground disturbance, so I try to stay vigilant to conditions and use 4wd only when needed. Obviously there is some risk in not leaving it in 4wd, but there are potential benefits as well. The trick is staying conscious. Better to exercise that response than a rote one that ultimately will result in complacence.
larry
   / Salesman said to only to use 4wd.... #45
larry
If you look back I beat you to this when I told LB .... I SAY!!
   / Salesman said to only to use 4wd.... #46
Yes, I answered as soon as I saw the incorrect post, before I saw yours. Still, I wouldnt have been, and was not competing, merely including some rationale.:)
larry
   / Salesman said to only to use 4wd.... #47
larry
Larry ... thats right I just didn't go back and read that. And again if it was meant to be fulltime 4x4 ... surely they would not have put a disengage lever!!!
   / Salesman said to only to use 4wd.... #48
BTW ... next time someone post ... MY FOUR WHEEL DRIVE ISN'T WORKING???
Maybe they will realize there is a lever to engage this feature and it simply is not meant for full time 4x4 ....
   / Salesman said to only to use 4wd.... #49
I think I just learned something (wow, that's a strange feeling).
I always thought that you could only bind up a 4WD that doesn't have a center diff. by turning on a hard surface. But if the front wheels are always turning faster than the rears by a little, then eventually, it sounds like it would bind up even going in a straight line.
That would also apply to my F350 pickup that doesn't have a center diff.
That's why sometimes, you have to rock a little forward/backwards to pop out of 4WD; there is load on gears in the transfer case.
   / Salesman said to only to use 4wd.... #50
I tend to keep the tractor in 2wd and use 4wd on a as needed basis. No real reason, just way my pea brain works.
Steve
74in FEL HD Round Back Bucket (A52128)
74in FEL HD Round...
2007 JOHN DEERE 310SJ BACKHOE (A50458)
2007 JOHN DEERE...
2013 Isuzu NPR-HD 16FT Reefer Box Truck (A50323)
2013 Isuzu NPR-HD...
2024 Ford F-350 Super Duty XLT FX4 - Like-New, Loaded, Only 780 Miles (A52128)
2024 Ford F-350...
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
2018 INTERNATIONAL 4300 BOX TRUCK (A51222)
2018 INTERNATIONAL...
