Ford 3000 - Blueish hue smoke story / question
   / Ford 3000 - Blueish hue smoke story / question #81
Didn't some of the "old" tractors have a factory built system to put an ether can in a holder and push a button to blow ether into the intake manifold while you sat on the seat and cranked the engine over!!! I know FORD and Deere had them on some of the larger machines.
Sure did but that is from a remote location. Quite different from spraying into the air intake while standing beside it.:D
   / Ford 3000 - Blueish hue smoke story / question #82
Some cat equipment does..
Plus some tractors have air intakes that are accessable by the driver, while setting in the seat... etc
soundguy
   / Ford 3000 - Blueish hue smoke story / question #83
All true but still does not mean one should be cranking and spraying unless one is remote from the blast path!:D
   / Ford 3000 - Blueish hue smoke story / question #84
Look at the way starter fluid works. It is much much easier to compression ignite than diesel. If you spray in several seconds of it into intake THEN crank, the first cylinder will get the majority of the shot. The either ignites while the piston is on the way UP making combustion pressure rise dramatically. The diesel that is coating the piston ignite raising the cylinder pressure even more as the piston continues to rise up. The normal fuel is then injected and immediately ignites rather than the normal slow controlled ignition. If you are "lucky" the engine starts. If you are "Unlucky" and sprayed in too much fluid or had all of it in 1 cylinder, you can blow the ring lands off and crack the piston skirts even bend the connecting rod.
Ether addicted engines have one or more compression ring lands hammered off. Pull some down and study them. I have, that's why I only will ever spray ether into a cranking engine so the ether is spread across several cylinders and the dose is limited. But that is only as a last resort.
Other folks have other opinions and as they say YMMV
jb
   / Ford 3000 - Blueish hue smoke story / question #85
No, I agree.. I've seen ether adicted pistons.. just like you say.. set back and broke ring lands.. holes pistons.. etc.. never see good parts coming out of a worn out ether addict..
soundguy
   / Ford 3000 - Blueish hue smoke story / question #86
Is this a new form of selective fluid dynamics under differential pressure?:confused:
   / Ford 3000 - Blueish hue smoke story / question #87
NOPE! Just the right way to do things when you want to get a job done safely and don't get hung up on mis-applied theory.
   / Ford 3000 - Blueish hue smoke story / question #88
Yup I did mention that once and then was baffled by some of that miss applied theory that got quoted.:D
   / Ford 3000 - Blueish hue smoke story / question #89
"miss applied" who is she?
2121 (A51244)
2121 (A51244)
2012 Ram 3500 Crew Cab Flat Bed Truck (A50323)
2012 Ram 3500 Crew...
Kivel Pallet Forks (A50121)
Kivel Pallet Forks...
2019 FORD TRANSIT CONNECT CARGO VAN (A52577)
2019 FORD TRANSIT...
2019 FREIGHTLINER M2 26FT BOX TRUCK (A52577)
2019 FREIGHTLINER...
