Smooth and level gravel driveways...
   / Smooth and level gravel driveways... #1
garc
Vancouver Island, BC, Canada.
05 Kubota B3030 ROPS
Click here and scroll to the bottom for pics of an 8 foot 200 pound rail attached to the bottom of a 370 pound box scraper. I really works!
   / Smooth and level gravel driveways... #2
VERY impressive
I'm jealous , Wish I had a need for that, as well as the need for the great tractor set up... :D
   / Smooth and level gravel driveways... #3
Really nice set up. The removable blade on the box blade is an excellent idea. Thanks for the pictures.
   / Smooth and level gravel driveways... #4
Great job with the photos! Thanks for sharing them and your ideas. Nice fabrication work.
   / Smooth and level gravel driveways... #5
nice top n tilt set up. If you use the tile on a backblade, does it give you enough tilt to do ditching?? ie lets say on a 7 ft blade, how much travel from level can you get at the end of the blade??
   / Smooth and level gravel driveways... #6
That thing is hooked up! I'll just have to keep adding stuff to my wish list. Very nice!
   / Smooth and level gravel driveways... #7
Dogonnit!!! You guys got to quit this neat stuff!!! I want all these cool things....
If you use the tilt on a backblade, does it give you enough tilt to do ditching??
Gerard, my LP 2572 RB is two weeks out in the shipping lanes so I'll give you the skinny on the 54" Kubota box blade: 4" down from horizontal at either end which doesn't sound like much until you put the cutting side wheels (54" O/A width on the B3030) into the deepening ditch as well. My tilt cylinder has a 4" range which is only 2" off horizontal @ 10.5" from the centerline on my side link so I would expect almost a 4:1 ratio on an 84" blade which could give you as much as 8" below horizontal. Ironically since you can't drive in the ditch with a tractor narrower than your blade we are about even on our ditching!
   / Smooth and level gravel driveways... #9
I don't think I can get more than 10 inches of tilt on my blade so your set up would give me the same range I have with a manually tilting blade without having to get out of my seat!!. Definitely the cadillac way to go! My next tractor will most definitely have remotes off the back, just haven't figured out if i really NEED more than three........
   / Smooth and level gravel driveways... #10
I've been thinking of doing the same thing, just hadn't gotten round to it. But I have to ask, when you use it are you in float or do you find it works best when not in float? Thanks,
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
SKID STEER ATTACHMENT HAMMER (A58214)
SKID STEER...
2020 CATERPILLAR 299D3 SKID STEER (A60429)
2020 CATERPILLAR...
2015 Freightliner 122SD T/A Day Cab Truck Tractor (A60460)
2015 Freightliner...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A55745)
2012 NORAM POWER...
E-Z Trail 20' Head Cart (A59814)
E-Z Trail 20' Head...
