DavesTractor
Elite Member
No water cooled engine will run cool with a clogged radiator, not even a JD.
Pull the radiator out and make sure it is 100% clean. Shine a light through it to check. 98% of the time that will solve the problem. Most people only get about half the radiator clean.
There have been a couple people on this site that have complained of overheating on the TYM built 3510/4110 Mahindras. We've sold a bunch of them and have not seen overheating problems, and we see over 110 degree heat in the summer. I think someone mentioned that the core may be too fine, and with the right sort of material in the air, it just clogs too fast. I had a skidsteer that was like that, and I had to clean the radiator way too often. I replaced it with a thicker core with more space between the fins. It was less efficient, but it did not clog near as easily, and the extra thickness gave enough cooling.
A tractor that overheats doesn't get any work done, and is frustrating, but I've never seen one that could not be made to run cool.
