GC 2310 one year later
   / GC 2310 one year later #1
JMynes
Auburn, Maine
Massey 2310
GC 2310 issues/solutions so far after one year of use (100 hrs);
Hit the corner of the house with an outrigger. Wake up and pay attention!
Flat rear tire, leaky rim weld. Dealer swapped me one off a new tractor.
Flat front tire, leaking around the bead. Bought a tube and installed it.
Blinker switch. Replaced under warranty.
Steering wheel bushings. Replaced under warranty, try not to use the steering wheel as a grab bar.
Contaminated Hydraulic oil. Trim vent tube so it won't suck up water.
Can't get enough seat time. Create more projects.
The dealership has been awesome! I hope it continues after the warranty lapses.
   / GC 2310 one year later #2
Is this what I get to look forward to with my GC2410?!
   / GC 2310 one year later #3
OK, here's mine after one year & 89 hrs:
Broke yellow warning light on corner of house (wake up & pay attention!)
Broke it again, same light/same place (@#%#$^$%!) Repaired myself both times-- CyA glue, styrene cement, epoxy
Found leak on BH hydraulic controls- repaired myself (tightened fitting)
Learned how to replace shearpins on snowblower:D:D
Added temp gauge, purchased Bro-Tek mechanical thumb (not on yet...)
Added M-F block heater ($$ but fits perfectly)
Other than "stoopid" stuff, no problems!
   / GC 2310 one year later #4
Just thought I'd chime in:rolleyes:
Broke light off house with canopy overhang
Leaking quick disconnect (dealer gave under warranty) I replaced it
Flat rear tire, bad rim seal. Tire Warehouse fixed for $5.00
Many shearpins last year (this year I put stakes down the driveway)
Paid for 50 hour service (should have done myself)
Thoroughly enjoy owning it!
Dang! I left out the shearpins! Let's just say, several. But that's an operator problem.
I haven't broken an orange light yet, but I've abused them a bit. Nice to know they glue back together, I hear they are crazy money.
What's the source (and part number) for that temp gauge? I'll be wanting one of those soon.
Actually I'm real happy with the performance so far.
Rear flat was a factory defect, the dealer made it good right on the spot.
Front flat, I think I rolled the bead on a rock. Once I decided it needed a tube, it was Saturday night and there was a storm due in. I called one of the dealership partners, he went out of his way to get me a tube that night so I could be ready for the next day. Tires, by the way, are not warranteed. They're covered by the tire manufacturer. Dealership doesn't try to get the bead to seat once they've unsealed, just put a tube in it and be done. I did it myself, and it was quite the wrestling match.
When the left blinker quit doing it's thing, I didn't care. Not worth a trip to the dealer, warranty or not. When I brought it in for the cab install I mentioned it and they replaced the switch.
While it was in for the cab install the mechanic discovered the steering wheel problem. I didn't even know it had an issue. They fixed it under warranty, too. Since then I've read on here that if you grab the steering wheel and hoist yourself onto the machine it causes that bushing to fail. I'm pretty sure that has been my mount/dismount technique since day one.
The hydraulic oil contamination is a design flaw. But it's an easy fix. The Hydro Trans vent tube is a loop of rubber hose that sits too close to an angle iron structural member. When the trans cools, the submerged end of the hose sucks up a little sip of water. Trim the hose, problem solved.
I love my tractor!
   / GC 2310 one year later #7
JMynes-- I just got a cheap "leftover" automotive gauge-- there's a good thread on that, so I won't take up space here, but I would advise a marine gauge-- mine isn't sealed very well, so it gets moisture inside the glass. Oh, well- ya gets what ya pays for! (It was only 10 bucks on a closeout, figured it was worth a shot.)
   / GC 2310 one year later #8
ME AND MY BIIIG MOUTH Just went outside to blow the driveway and snapped a shearpin JEEEEEZ! That's what I get for bragging about not breaking one this year!:mad:
   / GC 2310 one year later #9
At least they're easy to replace. I popped one the first time I used the SB and didn't even know it until I saw the snow piling up on one side of the auger. Haven't popped one since.
DEWFPO
   / GC 2310 one year later #10
After 3+ yrs and 450 hrs, only problem was shelling front pinion and ring gear, defective material, no charge for materials, was out of warranty for 2yrs, I did the labor myself.
This was not the dealer I had purchased the tractor from as they had gone out of business.
Just good customer relations and extending warranty for obvious factory defect!
   / GC 2310 one year later #11
Since you guys are talking about this then here are my experiences after almost a year and 255 hours.
Went twice to the shop:
First time:
- 50 hours service (done @ 80 something they (dealer) recommends it @ 100 hours)
- Replacement teeth for the back-hoe (changed it myself later)
- Replace a dented hydro filter and got a skip plate installed (dealer took care since it should have been installed in the first place but they forgot)
- Straightened the brake lever under the tractor
- Replace the plastic fan -- I cut a root and it went right up there while backing up. Careful with that!!! Dealer replaced it no charge must have been because of the missing skid plate
- Re-installed grease fitting (broke a few and still doing it)
- Got touch-up paint :)
Second time:
- 150 hours service (or probably more)
- Replacement teeth for the back-hoe (spare ones yup, rock digging!)
- Straightened the brake lever under the tractor (again)
- Replace a back-hoe cylinder main bolt (was touching the side of the boom and was wearing out factory defect forgot to mention at the first visit)
- Got a shop manual
- Got some rear tire chains installed (some kind of studded chain $$$ but awesome!)
I must be forgetting few things but I can say that I like this little beast and have no regrets! Spending too much time on it was painful for the butt and especially for one knee. Yes, it is possible to spend too much time on it in a day, ask my girlfriend!
   / GC 2310 one year later #13
As I remember, it was around $393, including shipping.... somewhat higher than the thumb for the BX Kubotas, as it's "a bit heavier" to quote Bro-Tek, and it comes with an adjustable top link that's thicker than the one that comes with the 3PH on the 2310, to fit the thumb (1" dia. pins).
   / GC 2310 one year later #14
Interesting. I got mine as part of the deal when I bought my tractor, and it uses the same top link as the 3PH.
I used it to lift and move some massive stumps and rocks to rebuild wall last summer and now can't imagine being without one. It's a winner in my book.
Jay
   / GC 2310 one year later #15
I'm really looking forward to using the thumb-- seems it's the one "most valuable" add-on for SCUTs. Got a lot of dead trees around my property, hoping to turn them into firewood.:D
Here's a coupla shots of the parts-- it's almost impossible to get a pic of the 2310's top link with the BH on, and I'm not takin' it off just now-- but I believe the pin diameter on the 2310's 3PH are 3/4"; you can see the relative size of the top link Richard @ Bro-Tek sent with the thumb.
The whole thing seems very well constructed, and the top link in particular very rugged. Even came painted red!
   / GC 2310 one year later #16
You're right - the 2310 pin diameter is 3/4", and it's the same on my Bro-Tek thumb. I just take the top link off when I attach the BH and it rests nicely on the platforms where my feet rest when I'm using it.
Wish I could find some pictures of the rocks and stumps I picked up and moved thanks to the thumb, they were impressive.
All this talk of digging stuff is really giving me serious Spring fever. Sadly, the ground is still very, very frozen.... :(
   / GC 2310 one year later #17
well JMynes,happy anniversery, I'm celebrating the first year also. 150hrs, lots of rocks and landscaping last summer, not nearly enough snow this year (just for play purpose othe then that there's always too much)
in the first month, lets's see: scraped the right flasher light against the house,(way too close!), first week end trying the BH scraped the front bumper of my wife's car,(She laughed and tells the story all the time) grease zert was broken (repalced withoutcalling the dealer ) oh yah 1 more thing.. Always smiling when I work. love the machine, want a bigger one for no reason, and love helping out the neighbors.
I forgot to mention the white plastic HST cooling fan. I managed to break all but two blades off of it. If you hear a hellacious grinding noise under your tractor, it's probably something attacking your fan.
Ordered from the dealer, not too expensive. I spent too much time trying to change it from under the tractor. I ended up loosening the floor pan and raising it in the back about 2 inches which made it easy.
   / GC 2310 one year later #19
Been over a year, but...
I lost one of my orange lights on a tree.
My stabilizer arms on the 3PH have bent pretty severely from using my box blade, no matter how careful I am backing up, I seem to hit and they bend.
Lost the adjustable stabilizer arm sometime when I had the BH attached. I take them off now.
Learned a lot about hydraulics, dirt, balance
Founds Lotsa helpful folks on TBN.
Never enough time in the seat.
Dan
   / GC 2310 one year later #20
This happened to a friend who has a BX Kubota, but thinks it is a Caterpillar bulldozer. He straightened the arm out with some heat and a hammer, then welded a steel plate to the bottom that reinforced the arm. It is now *very rugged* and he has used his blade a lot since this modification and there is no hint of a problem.
I think he posted some pictures on TBN - you could search for his posts: TBN handle is "Dyer, retired".
Jay
2017 Toyota Camry Hybrid Sedan (A59231)
2017 Toyota Camry...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
Zero Turn Mower (A59231)
Zero Turn Mower...
2022 CATERPILLAR 242D3 SKID STEER (A60429)
2022 CATERPILLAR...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
2004 JOHN DEERE 160C LC EXCAVATOR (A52709)
2004 JOHN DEERE...
