PICTURES comparing my new set up to the old one
   / PICTURES comparing my new set up to the old one
Related question do most guys have fuel delivered.How much extra for delivery
Framer
I get my off road delivered.
There is no delivery charge so it cost the same delivered or picked up.
Where I live small amounts of off road are at least .25 higher than on road is at the station.
Off road here is about 40 cents a gallon less than on road is at the stations.
I get my off road delivered 55 gallon at a time.
The cost per gallon is the same delivered or picked up.
   / PICTURES comparing my new set up to the old one #32
1*What is on the end of your vent set up?
2*About what would it cost to do your setup on the plumbing?
I know what the pumps run and I can get barrels Thanks
1*I made a screen out of aluminum screen door wire and clamped it on the end of the street el with a hose clamp to keep bugs and other objects from getting into the drum .
2*I estimate I have about $275 to $325 in the set up.
Just deduct your cost of the pump and drum from that and it should give you a ball park figure for the items you inquired about.
What is on the end of your vent set up?About what would it cost to do your setup on the plumbing? I know what the pumps run and
I can get barrels.
Where do you get get drums and what do they cost ?
I had trouble finding them around here.
Took quite a while to locate them.
   / PICTURES comparing my new set up to the old one #35
After searching and inquiring locally for over a week with no luck, I bought online from Gempler's.
My 15 gallon, 2 handled drum was $39.95 plus another $10 or $12 to ship. It arrived 4 days after ordered.
   / PICTURES comparing my new set up to the old one #36
Just call DeWitt barrel. They have a boatload of refurbished drums ready to go!!!!
   / PICTURES comparing my new set up to the old one #37
I know a place that buys detergent and window cleaner in them I can get and one of the farm stores sells them.
   / PICTURES comparing my new set up to the old one #38
L.... I think a good addition to your fuel system would be to add desiccant drum vents to the drums. My two 55 gallon drums each have one on to help keep my drums moistrue free.
Drum Desiccant Breathers: Standard & Heavy Duty Industrial & Ultra Clean
Hey Jim, you posted info on drum desiccant breathers and said you use 2 of them on your 55gal. drums, (1 each). I am in the process of building a diesel fuel caddy and I have taken something from a lot of contributing members, and I want to install one of these on my caddy, I've gotten a price for one of the dryers and it's expensive, I was quoted 150.00 for a standard duty one, that's a lot and I was wondering if you paid that for yours? Do you know of a more reasonable solution to get a desiccant dryer for a 25gal. fuel caddy. Thanks.
   / PICTURES comparing my new set up to the old one #39
Your new set up looks great, but if it were mine, I would have it looking crowded and in need of more room in about a month, :laughing:. KC
2016 Bobcat E85 Midi Excavator (A59228)
2016 Bobcat E85...
CAT 930M (A58214)
CAT 930M (A58214)
KOMATSU D155AX-8 CRAWLER DOZER (A60429)
KOMATSU D155AX-8...
2012 FREIGHTLINER CL120 CONVERTED TANDEM AXLE GLIDER DUMP TRUCK (A59905)
2012 FREIGHTLINER...
Rooster Weathervane (A55853)
Rooster...
2012 Ford F350 Flatbed Truck (A59814)
2012 Ford F350...
