L2800 front end fluid change
   / L2800 front end fluid change #1
DanielTerence
Kubota L2800
Changed the fluid in the front end of my L2800 HST this past weekend. It was supposed to take 4.8 quarts (if I remember correctly). I could only pour in about 2 quarts before it started coming out the check hole. I did not measure what had drained out (the old fluid) until afterwards and it was only about 2 quarts.
I had let the fluid drain for about an hour (it was slowly dripping out) so I figured it was empty when I started to refill.
So, I guess I only got about 1/2 of the fluid out, but I don't know where the rest was?
   / L2800 front end fluid change #2
It takes a while for the new fluid to settle.
I'd check it again.
   / L2800 front end fluid change #3
Yes wait a day and check it again.
   / L2800 front end fluid change #4
wait-- aren't you supposed to shake the container to get it all out?
err. oh this was way the oil can..
I had the same issue.. Someone else on here stated that not all of it comes out...
and I remember another post that someone said to use one of those oil pumps..-- I did not think that was a good idea....
Later,
J
   / L2800 front end fluid change #5
I thought you could raise the front tires off the ground with the FEL and tilt the axle to one side to get more out... It's been to long ago when I did it... (many, many beers ago).
I did let it sit for two days. The level had not changed. So basically, I drained 1/2 gallon out and put 1/2 gallon back in. I'm assuming that I diluted whatever old fluid remained - so I'm not going to worry about it.
Thanks for the input everyone.
   / L2800 front end fluid change #7
I got 4 quarts into mine after I drained it, Kuboto used gear oil judging by the time it took to drain it. Using both drain plugs you should be able to drain more than 2 quarts.
   / L2800 front end fluid change #8
What type of oil and weight or you guys using?
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
54in Loader Fork Attachment (A59228)
54in Loader Fork...
John Deere 7410 (A53317)
John Deere 7410...
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
