L2800 front end fluid change
   / L2800 front end fluid change #1
DanielTerence
Kubota L2800
Changed the fluid in the front end of my L2800 HST this past weekend. It was supposed to take 4.8 quarts (if I remember correctly). I could only pour in about 2 quarts before it started coming out the check hole. I did not measure what had drained out (the old fluid) until afterwards and it was only about 2 quarts.
I had let the fluid drain for about an hour (it was slowly dripping out) so I figured it was empty when I started to refill.
So, I guess I only got about 1/2 of the fluid out, but I don't know where the rest was?
   / L2800 front end fluid change #2
It takes a while for the new fluid to settle.
I'd check it again.
   / L2800 front end fluid change #3
Yes wait a day and check it again.
   / L2800 front end fluid change #4
wait-- aren't you supposed to shake the container to get it all out?
err. oh this was way the oil can..
I had the same issue.. Someone else on here stated that not all of it comes out...
and I remember another post that someone said to use one of those oil pumps..-- I did not think that was a good idea....
Later,
J
   / L2800 front end fluid change #5
I thought you could raise the front tires off the ground with the FEL and tilt the axle to one side to get more out... It's been to long ago when I did it... (many, many beers ago).
I did let it sit for two days. The level had not changed. So basically, I drained 1/2 gallon out and put 1/2 gallon back in. I'm assuming that I diluted whatever old fluid remained - so I'm not going to worry about it.
Thanks for the input everyone.
   / L2800 front end fluid change #7
I got 4 quarts into mine after I drained it, Kuboto used gear oil judging by the time it took to drain it. Using both drain plugs you should be able to drain more than 2 quarts.
   / L2800 front end fluid change #8
What type of oil and weight or you guys using?
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
2006 Trail King RGN 45ft. Heavy Haul Lowboy Equipment Trailer (A60460)
2006 Trail King...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
