Removing a bush
   / Removing a bush
How about pouring some diesel fuel on it and torching it.
Thanks! That's exactly how I intend to get rid of the brush pile it's been sitting on for a couple weeks.
   / Removing a bush #52
   / Removing a bush #53
Freds,
I am sure glad you gave that hoe a good workout.
JJ, did you say what you mean or just mean what you said? :) ;)
This thread gave me and interesting idea.. Virtual Projects!
The person would give pictures of the problem. Take suggestions for a week, then go outside and try the suggestion. When/if there is a snag (no plan survives contact with the enemy), the person comes back, takes suggestions for a week and then tries the new idea. The idea is don't do anything on your own and stop when a new idea/plan is warranted. You could make a project take 2 months and we could all be playing "Virtual Project" till it's done. Sounds like fun!
   / Removing a bush #55
CrownHawg, Looks like that Deere needs a Kioti on it's butt!!
   / Removing a bush
Crownhawg, you aren't "just" doing anything when you've got a wheel in the air :eek:
   / Removing a bush #57
OK, it's a little light in the arse. I'm working on getting some weight back there. It looks alot more "dangerous" than it really was. I actually pulled out 5 of those pesky boxwoods. This particular one had some extra big roots. With the ehydro, I can ease into (or out of) this dog peeing stance. So far, I have found this little tractor has alot more power than weight. Everyone tells me to "fill" the tires, but I would really like to be able to go light when I want, then just load up with weight when needed. Still looking.
   / Removing a bush #58
Are you lifting from one side of the bucket causing the wheels off the ground? If you have two hooks, the best way is to put a chain in both hooks and lift from the back center of the bucket, or a hook in the center doing the lifting from the back of bucket.
Adams 8 Ton Weigh Hopper (A55301)
Adams 8 Ton Weigh...
Peterbilt 377 Semi-Truck (A55218)
Peterbilt 377...
2014 FORD F-350 (A53843)
2014 FORD F-350...
2020 FREIGHTLINER DEBRIS BUCKET TRUCK (A51406)
2020 FREIGHTLINER...
SDLANCH TRACKED MINI LOADER (A53843)
SDLANCH TRACKED...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
