Removing a bush
   / Removing a bush
How about pouring some diesel fuel on it and torching it.
Thanks! That's exactly how I intend to get rid of the brush pile it's been sitting on for a couple weeks.
   / Removing a bush #52
   / Removing a bush #53
Freds,
I am sure glad you gave that hoe a good workout.
JJ, did you say what you mean or just mean what you said? :) ;)
This thread gave me and interesting idea.. Virtual Projects!
The person would give pictures of the problem. Take suggestions for a week, then go outside and try the suggestion. When/if there is a snag (no plan survives contact with the enemy), the person comes back, takes suggestions for a week and then tries the new idea. The idea is don't do anything on your own and stop when a new idea/plan is warranted. You could make a project take 2 months and we could all be playing "Virtual Project" till it's done. Sounds like fun!
   / Removing a bush #55
CrownHawg, Looks like that Deere needs a Kioti on it's butt!!
   / Removing a bush
Crownhawg, you aren't "just" doing anything when you've got a wheel in the air :eek:
   / Removing a bush #57
OK, it's a little light in the arse. I'm working on getting some weight back there. It looks alot more "dangerous" than it really was. I actually pulled out 5 of those pesky boxwoods. This particular one had some extra big roots. With the ehydro, I can ease into (or out of) this dog peeing stance. So far, I have found this little tractor has alot more power than weight. Everyone tells me to "fill" the tires, but I would really like to be able to go light when I want, then just load up with weight when needed. Still looking.
   / Removing a bush #58
Are you lifting from one side of the bucket causing the wheels off the ground? If you have two hooks, the best way is to put a chain in both hooks and lift from the back center of the bucket, or a hook in the center doing the lifting from the back of bucket.
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A55218)
Greenworks...
19200 (A50324)
19200 (A50324)
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2015 FREIGHTLINER...
Utility Trailer (A52377)
Utility Trailer...
2017 FORD F250 SUPER DUTY EXT CAB SERVICE TRUCK (A53843)
2017 FORD F250...
1984 Ford LTD Crown Victoria (A52377)
1984 Ford LTD...
