How to calculate the amount of SCA/DCA needed.
   / How to calculate the amount of SCA/DCA needed. #1
DieselPower
Elite Member
Fairfield, PA
JD 3020, JD 4230, JD 7410, JD 2440, MF 750, NH LS170
There was a comment made in another thread about how much of a PITA it is to figure out how much DCA/SCA you need to add to your coolant when using test strips. Personally I never really gave it any thought since I have a handy little slide chart that was given to me years ago when I worked for a International truck dealership. I guess it's one of those things you never realize how handy something is until you think about it.
In any case, I have scanned and uploaded pictures of the chart. The first two pictures are of the outside of the slide chart. The third and fourth pictures are of the internal slide card. The fifth picture is of what it will look like assembled. Please pardon the greasy finger prints, it's seen a lot of use over the years. :)
Probably the easiest thing to do is print out the first four pictures. Just right click over the picture and then select print. Trim the pictures out. Cut out the viewing windows in the first and second pictures and a slot at the top to grab the internal card by. Tape the first and second pictures together along the left and right sides. Tape the third and fourth pictures together back to back (be sure it is cut small enough to slide into the previously assembled outside). Now just slide the number chart in the outer body. Using a DCA/SCA test strip take the reading you get with it and slide the internal card out until that number is showing. Find the approximate capacity of your cooling system and the number below it is the amount of DCA/SCA you need to bring it up to about 3.0.
Moderators - Feel free to make a sticky out of this to make it easier for people to find.
http://www.tractorbynet.com/photos/data/500/DCA1.JPG
http://www.tractorbynet.com/photos/data/500/DCA2.JPG
http://www.tractorbynet.com/photos/data/500/DCA3.JPG
http://www.tractorbynet.com/photos/data/500/DCA4.JPG
http://www.tractorbynet.com/photos/data/500/DCA5.JPG
   / How to calculate the amount of SCA/DCA needed. #2
The best practice for maintaining the DCA level in diesel engine coolant is to use the manufacturer's recommendation on either how much liquid to add or the correct service filter that is used at each PM interval.
Using your chart method can lead to some who will want to keep the DCA level at the minimum level. False economy as this usually results in having levels in the range of less than 1.2 units per gallon (Fleetguard method) or 1200 PPM nitrite (Penray, Detroit Diesel method) and eventually, cylinder wall cavitation pitting failure.
For sake of good practice and simplicity, the service dose of DCA (Fleetguard DCA4 or DCA2) is one unit per 3 gallons of system capacity. On a 12 gallon system, that is 4 units. Fleetguard DCA4 Liquid is 5 units per pint bottle. Use of Pencool 2000 or 3000 has the equivalent treatment of 4 units per pint. Use either or even mixing the two supplemental coolant additive bases will work. If you use the Fleetguard CC2602 test strips (available in single pack and packs of 4 strips), continue to add the liquid at each PM interval for your tractor or machine. When testing indicates you have exceeded 3.0 units per gallon, do not add liquid or change the coolant filter (if your engine uses chemical charged filters). When the DCA level drops below 3.0 units per gallon, resume the service dose or filter change.
   / How to calculate the amount of SCA/DCA needed. #3
I'm not an engineer; just a lowly mechanic. I find the notion of dosing DCA supplements based on the calendar or hour meter while ignoring coolant test results to be absurd. I really can't describe it any other way.
   / How to calculate the amount of SCA/DCA needed. #4
If one knows the total amount of their coolant SYSTEM..all one needs to do is use the test strip...record the results and then call FleetGuard on the telephone. You can tell them what the test strip indicated and they will tell YOU how much of what you need...and charge you for it and drop it in the mail to you. Dont know what can be easier than that???
   / How to calculate the amount of SCA/DCA needed. #5
Trust me on this one, calling Fleetguard to find out how much to add based on the test strip reading will NOT get you an answer. Their technical assistance people do not work off charts such as you describe nor do they any other charts. They will state that DCA (or SCA) needs to be added on a maintenance basis of hours of operation such as what Cummins or Caterpillar would state for their engines.
For the comment made earlier that it is absurd to use engine hours as a basis for doing coolant service, why do you think engine hours based oil change intervals are okay and not so for coolant? Many engines have 250 engine hours as the basis for changing oil and filter. Is that 250 hours at low speed and low to moderate load levels or is that 250 hours at all maximum engine load? Engine companies do not differentiate on standard service intervals. The same for coolant service. if you have leakage and refill low coolant levels with coolant approved by your tractor manufacturer and never refill with plain water or water/antifreeze mixes, the service filter or liquid dose is sufficient to replenish what your engine consumed by running. On the other hand if you are topping off low coolant levels with whatever you pour in, the likelihood of damage from cavitation pitting is much greater. Testing does tell you if your maintenance program is correct for the hours you are running.
What is your goal in coolant precharge? Do you want to keep it at the bare minimum level of 1.2 units per gallon? Or do you keep it at 3.0 units per gallon and the upper end of precharge? Keeping it at bare minimum means you dip into the "precharge" range meaning the DCA protection is so low that cavitation pitting can set in. Keeping to the higher end keeps you away from that danger zone.
If you like to test and make your determination that way, good. That is more money for Fleetguard and other companies. Should you have issues with a cavitation pitting failure, all engine companies will refer you to their published cooling system service interval information. None of them will tell you to test to decide if or how much DCA to add. You are on your own. Good Luck from a Fleetguard Service Engineer, Gary Spires 8^)
   / How to calculate the amount of SCA/DCA needed. #6
Rick,
Nothing lowly about being a service professional. Without you, things will come to a halt. Which of the equipment engines that you repair and service recommends testing coolants for DCA or SCA levels instead of following their maintenance chart on liquid dose or coolant filter change? If you are repairing equipment that does not have such maintenance instrucitons as when to add the dose or change the filter, perhaps that engine does not need the chemical addition. Cummins B5.9L and ISB 5.9L engines are examples of diesel engines that do not have coolant maintenance recommendations that require use of DCA as those engines do not have cavitation pitting failures.
   / How to calculate the amount of SCA/DCA needed. #7
Rick,
I use Fleetguard test strips and the accompanying chart to determine need and dosage. I'm not sure why Fleetguard's technical staff would not support their own product if I called, but I haven't, so I have no knowledge of whether they endorse and support their own products.
   / How to calculate the amount of SCA/DCA needed. #8
I disagree 1000%. I did exactly as they directed me to do and they sent me the pint bottle and told me how much to add.
I'm kind of suprised you say to add DCA based on time and not based on what the system actually needs to bring it back up to 3.0. I have seen systems first hand that were treated on a time basis and that had DCA levels that were to high and on the same note have seen ones that were way, way low. It also seems kind of strange since the card I posted here was issued by International and came with a letter from Fleetguard telling the mechanics how to use it properly. I'll have to look around and see if I still have the letter from Fleetguard.
   / How to calculate the amount of SCA/DCA needed. #10
DieselPower: If I read your first post correctly...then you and I are saying the same things....with the exception that you HAVE the "chart" and the lady I talked with at FleetGuard had to look at her's and then tell me what I needed. I distinctly remember asking her a question ( I forget what exactly the question was...but do remember it petained to useing their "extender" in my coolant) and her telling me to hold on a second because she had to look at a different "chart".
I was told by them to use the "time thing" as a basis for CHECKING my coolant...not as to actually ADDING anything. When checked on the time basis using their test strips...then I can tell what I have at that point and then decide to add DCA or not....depending on the actual reading.
   / How to calculate the amount of SCA/DCA needed. #11
Guys,
I will not argue on this. But as the main coolant service engineer for Fleetguard, I can assure you that what I state is chapter and verse of engine company recommendations on treating cooling systems with DCA or similar additives. If you like the test and add method and you keep the SCA level at a decent level....bless you and glad it is working. If you test and add just enough to make it into the green zone, watch out!
I recall International several years ago cutting that document about using their method of add per the test strips. As to a letter from Fleetguard, it did not come from Service Engineering, likely came from a marketing and sales person who (in our company) usually is clueless about technical subjects.
   / How to calculate the amount of SCA/DCA needed. #12
Here is an excerpt for Cummins QSC8.3L industrial engines on Coolant Maintenance from the Maintenance Schedule. Read down to the ag engines and note: 500 hours or 6 months on coolant maintenance.
  • QSC8.3_QSL9.0 Maintenance Schedule.pdf
   / How to calculate the amount of SCA/DCA needed. #13
I dont know how old that PDF file is but 2 things I did notice:
Drain the coolant every 2 years.. I use Fleetguard Complete and by adding their "extender" it NEVER has to be changed unless the phosphate level gets out of whack.
And also change the "coolant filter". On many of the new Cummins engines there IS NO coolant filter ( its an empty can is all) and DCA/SCA is controlled by the addition of FleetGuards chemicals
   / How to calculate the amount of SCA/DCA needed. #14
Close but not quite accurate, Sully. Not many Cummins but two models do not have coolant filters, all B5.9L including ISB, QSB as well as latest ISB 6.7 automotive engine and ISL 9L models. C8.3 found in many ag machines and ISC have a coolant filter. Originally, when Cummins ships engines to OEMs they are equipped with a maintenance size filter with DCA4. The Application Engineering group informs the OEM what the coolant requirements are for the engine in question. As for that Maintenance Schedule, it is the latest publication for C, ISC, and ISL engines. On the ISL engines, Cummins informs the OEM builder that a coolant filter should be installed leaving them to purchase a remote head and plumbing to make that happen. If coolant filters are not used, no harm as performing service with liquid is acceptable to Cummins. All engine companies have some maintenance schedule that states coolant life and change internvals. I certainly agree that use of Fleetguard ES Compleat can have a much longer service life than Cummins recommends. But still, engine companies have maximum change intervals based on the coolant products that they prefer. Caterpillar is an example of having change intervals based on coolant product they sell or find acceptable.
   / How to calculate the amount of SCA/DCA needed. #15
ISB engines in motorhomes dont have a filter..because Cummins says that DCA/SCA isnt needed at all. ISC engines..again in motorhomes...USED TO HAVE a coolant filter..(my own ISC does) but ISC's built in the last 2 ( or maybe 3??) years dont have....and there isnt a single ISL engine in any motorhome that has one.
I wont argue the point further because you are the "engineeer"..but I know what I see and have called Cummins enough times about different items that Im almost on a first name basis!
   / How to calculate the amount of SCA/DCA needed. #16
can someone please fill in the blanks i have no idea what you guys are talking about, and i starting to think that i might need to know. i own a cummins and my tractor has a mitsubishi. am i the only one who does not know what they are talking about? what is sca/dca?
   / How to calculate the amount of SCA/DCA needed. #17
The terminology of SCA is Supplemental Coolant Additive. Since one company, Fleetguard, makes these coolant additives under the trade name of DCA4 or DCA2, the generic term has become DCA. What these chemicals do in your engine cooling system is to provide protection against cylinder wall cavitation pitting failures. When a diesel engine runs it produces cylinder wall vibrations from combustion and piston slap. These vibrations produce minute movement of the cylinder wall that cause vacuum bubbles to form in the coolant. These bubbles implode (like explode but inward, not outward) against the cylinder wall surface with forces measured at 20,000 PSI. Sufficient force to break out tiny pieces of the cast iron eventually leading to coolant getting into the oil through a perforation. Engine rebuild is the only option then. Use of SCA or DCA creates a tough oxide film on the surface of the cylinder wall (coolant side). The testing of the dissolved SCA level is an indirect means of determining the level of cavitation resistance your coolant has. Even with these additives, the phenomenon of cavitation is taking place. The difference is the hard oxide coating that takes the "blast" of implosion. If you test the coolant and find the SCA level decreasing, you have a strong indication that the cavitation phenomenon is active in your engine. If your Cummins is a B5.9L or QSB (24 valve with Electronic Control Module, ECM) you have no reason for concern regarding cavitation damage. As an employee of Cummins, I work with Mid Range Service (B, C, & L). Only the B engines are immune. C and ISL engines do have cavitation and must have coolants that contain SCA and also require periodic replacement of the coolant filter or use of a liquid SCA additive.
   / How to calculate the amount of SCA/DCA needed. #18
not sure what my engine is it's a 99 24 valve 53 series block. do i need to worry about this on my tractor motor it's a mitsubishi s4l?
   / How to calculate the amount of SCA/DCA needed. #19
Not sure about that block number business but I read on a website for Dodge Cummins engines of that block number as realated to some casting issues. I am certain you have a QSB 5.9L. Does it have individual valve covers instead of one long valve cover? QSB and ISB per Cummins do not require the use of SCA treatment in the coolant. If your tractor operation and maintenance manual has a scheduled coolant service, follow their instructions as they warrant the tractor/engine, not Cummins. That same engine in Dodge pickups does not require the use of SCA treated coolants. However, if you desire to use that type of coolant, do so. It will make the coolant much more robustly formulated and increase the coolant's service life.
2015 CATERPILLAR  XQ30 GENERATOR (A58214)
2015 CATERPILLAR...
2425 (A60432)
2425 (A60432)
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
Rotating Brush Sweeper Tractor Attachment (A59228)
Rotating Brush...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 FREIGHTLINER CASCADIA TANDEM AXL MID ROOF SLEEPER TRUCK (A59905)
2016 FREIGHTLINER...
