Troy-Bilt tiller stuck Forward-Reverse lever
   / Troy-Bilt tiller stuck Forward-Reverse lever #1
Old Hogger
Working on a 1982 Horse tiller that has been sitting for 12 years. Having trouble getting the forward/reverse lever to operate. I know where it is froze up. And I don't need to break the housing while getting the old girl to move. Any ideals? Heat is my second thought after waiting a few days on w-d forty to work. Ordered a manual today. Thanks.
   / Troy-Bilt tiller stuck Forward-Reverse lever #2
Be careful. Don't force. It's easy to bend or break the Forward-Reverse lever. All parts are available through MTD to rebuild the Forward-Reverse mechanism.
I have a 1976 Troy-Bilt Horse with a 6HP Tecumseh engine. I had the Forward-Reverse lever reinforced at a local welding shop. A strip of 1"X 1/4" steel was welded to the topside of the lever. Now it will not bend or break.
   / Troy-Bilt tiller stuck Forward-Reverse lever #3
It would help to know where it is rusted together. There are only a few places that can be froze and they are easily disassembled by removing a few bolts and separating the parts.
The motor mount bars are stuck fast. Sorry about not filling in the big hole in my post.
   / Troy-Bilt tiller stuck Forward-Reverse lever #5
Lots of Kroil penetrating oil. Or take it all apart and clean the surfaces on a wire brush wheel.
Sliding free and happy. After spraying it for four day I finally took it apart and tapped it with a small hammer. Thanks for the in put.
   / Troy-Bilt tiller stuck Forward-Reverse lever #7
Is it running? :)
   / Troy-Bilt tiller stuck Forward-Reverse lever #8
JakeBrake, any chance you could post a picture of the reinforced welded repair to the Forward-Reverse lever? thanks in advance.
   / Troy-Bilt tiller stuck Forward-Reverse lever #9
Hope this helps.
   / Troy-Bilt tiller stuck Forward-Reverse lever #11
Thanks JakeBrake.
I've been thinking I need to reinforce my lever and now I know how to do it.
-Len
17102 (A56859)
17102 (A56859)
FENCE PANELS (A58214)
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
2022 CATERPILLAR 303.5CR EXCAVATOR (A60429)
2022 CATERPILLAR...
2014 GENIE GTH-5519 TELESCOPIC FORKLIFT (A60429)
2014 GENIE...
