Troy-Bilt tiller stuck Forward-Reverse lever
   / Troy-Bilt tiller stuck Forward-Reverse lever #1
Old Hogger
Working on a 1982 Horse tiller that has been sitting for 12 years. Having trouble getting the forward/reverse lever to operate. I know where it is froze up. And I don't need to break the housing while getting the old girl to move. Any ideals? Heat is my second thought after waiting a few days on w-d forty to work. Ordered a manual today. Thanks.
   / Troy-Bilt tiller stuck Forward-Reverse lever #2
Be careful. Don't force. It's easy to bend or break the Forward-Reverse lever. All parts are available through MTD to rebuild the Forward-Reverse mechanism.
I have a 1976 Troy-Bilt Horse with a 6HP Tecumseh engine. I had the Forward-Reverse lever reinforced at a local welding shop. A strip of 1"X 1/4" steel was welded to the topside of the lever. Now it will not bend or break.
   / Troy-Bilt tiller stuck Forward-Reverse lever #3
It would help to know where it is rusted together. There are only a few places that can be froze and they are easily disassembled by removing a few bolts and separating the parts.
The motor mount bars are stuck fast. Sorry about not filling in the big hole in my post.
   / Troy-Bilt tiller stuck Forward-Reverse lever #5
Lots of Kroil penetrating oil. Or take it all apart and clean the surfaces on a wire brush wheel.
Sliding free and happy. After spraying it for four day I finally took it apart and tapped it with a small hammer. Thanks for the in put.
   / Troy-Bilt tiller stuck Forward-Reverse lever #7
Is it running? :)
   / Troy-Bilt tiller stuck Forward-Reverse lever #8
JakeBrake, any chance you could post a picture of the reinforced welded repair to the Forward-Reverse lever? thanks in advance.
   / Troy-Bilt tiller stuck Forward-Reverse lever #9
Hope this helps.
   / Troy-Bilt tiller stuck Forward-Reverse lever #11
Thanks JakeBrake.
I've been thinking I need to reinforce my lever and now I know how to do it.
-Len
2019 KOMATSU D61PXI-24 CRAWLER DOZER (A60429)
2019 KOMATSU...
2017 Scag Cheetah 61in Zero Turn Commercial Mower (A59228)
2017 Scag Cheetah...
New Holland 3930 (A60462)
New Holland 3930...
Champion Vibratory Roller (A60462)
Champion Vibratory...
2018 F550 Bucket Truck (A61306)
2018 F550 Bucket...
XCMG CV83PD (A53317)
