Troy-Bilt tiller stuck Forward-Reverse lever
   / Troy-Bilt tiller stuck Forward-Reverse lever #1
Old Hogger
Working on a 1982 Horse tiller that has been sitting for 12 years. Having trouble getting the forward/reverse lever to operate. I know where it is froze up. And I don't need to break the housing while getting the old girl to move. Any ideals? Heat is my second thought after waiting a few days on w-d forty to work. Ordered a manual today. Thanks.
   / Troy-Bilt tiller stuck Forward-Reverse lever #2
Be careful. Don't force. It's easy to bend or break the Forward-Reverse lever. All parts are available through MTD to rebuild the Forward-Reverse mechanism.
I have a 1976 Troy-Bilt Horse with a 6HP Tecumseh engine. I had the Forward-Reverse lever reinforced at a local welding shop. A strip of 1"X 1/4" steel was welded to the topside of the lever. Now it will not bend or break.
   / Troy-Bilt tiller stuck Forward-Reverse lever #3
It would help to know where it is rusted together. There are only a few places that can be froze and they are easily disassembled by removing a few bolts and separating the parts.
The motor mount bars are stuck fast. Sorry about not filling in the big hole in my post.
   / Troy-Bilt tiller stuck Forward-Reverse lever #5
Lots of Kroil penetrating oil. Or take it all apart and clean the surfaces on a wire brush wheel.
Sliding free and happy. After spraying it for four day I finally took it apart and tapped it with a small hammer. Thanks for the in put.
   / Troy-Bilt tiller stuck Forward-Reverse lever #7
Is it running? :)
   / Troy-Bilt tiller stuck Forward-Reverse lever #8
JakeBrake, any chance you could post a picture of the reinforced welded repair to the Forward-Reverse lever? thanks in advance.
   / Troy-Bilt tiller stuck Forward-Reverse lever #9
Hope this helps.
   / Troy-Bilt tiller stuck Forward-Reverse lever #11
Thanks JakeBrake.
I've been thinking I need to reinforce my lever and now I know how to do it.
-Len
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
JEEP FOR DOUBLE TRAILER (A58214)
JEEP FOR DOUBLE...
20704 (A55853)
20704 (A55853)
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A56438)
2002 Chevrolet...
