starting an old tractor for the first time in 15 years
/ starting an old tractor for the first time in 15 years #1
electricvet
western kansas
1957 case 400
My Father-in-law has recently given me a 1957 case 400 tractor. The tractor was "rebuilt" in the late 80'sand then was parked in the mid 90's inside a shed. He states that it ran fine the day it was parked. To shorten this story, what is the best steps in getting this thing started? I only know that it is a gas engine, I do not know if it is a 6 volt or 12 volt system (it will need a battery first thing), The tractor is about five hours away and I would like to try and get it running in a weekend so I can drive it on a trailer and bring it home! Any help would be great!
/ starting an old tractor for the first time in 15 years #2
With Antiques...
We always change the fluids and filters... after checking to make sure the motor isn't frozen with a large socket on a cheater bar or rocking the vehicle back and forth in 3rd or 4th gear.
When it does start... we never let the engine run for more that a few minutes while listen and looking for problems and checking the gauges.
You may need to set up an alternative fuel source... no telling what's in the tank.
Sound like a fun project!
hey thanks, now another question, the tractor needs a battery sooo, how do I tell if it a 6 volt or 12 volt system? Thanks for any help!
/ starting an old tractor for the first time in 15 years #4
Normal lead acid batterys are 2 volts per cell. Each cell needs it's own fill cap
so a 6 volt battery had 3 caps and a 12 volt has 6 caps.
OK that info is good, but the tractor has no battery in it as it was "robbed" a long time ago, how can I tell if it a 6 volt system or 12 volt system? Is there some trick or maybe a label on the generator? Also in reading on this website, there has been some mention of a positve ground system, would this apply to me or not?
/ starting an old tractor for the first time in 15 years #6
TractorData says it's 6V.
TractorData.com J.I. Case 400 tractor information
If you're sure it's a gasser, then it's a Case 400B (37 hp pto) with a 4-cyl Case-built engine.
The Case 400 is the diesel version.
It's fairly heavy (3900 lb), but you might be able to winch it onto your trailer if you can't get it running.
I would remove the plugs and rock the tractor by pushing on the rear tires to see if the engine is stuck (watch the fan for motion).
Clean or replace the spark plugs. Ask your FIL to check the type of plug that's in the tractor now and get a new set if you don't want to spend time cleaning and gapping the old plugs.
Bring some 10W40 motor oil and an oil filter and do an oil change. Your NAPA store can ID the filter for you.
Fill the radiator with water.
Drain the old gas, if any, from the tank. Add fresh fuel if you think the tank is clean. Otherwise rig up gas delivery from a temporary 1 gallon container. Clean the sediment out of the fuel filter bowl.
My guess is that it's a 4-cyl flat head engine with an updraft carburetor. You need to make sure the carburetor is feeding gas to the cylinders. You may have to remove the carburetor, connect the fuel line and work the throttle linkage to see if you're getting gas flow.
Try to start it. You may get lucky and get it running.
However, if it's like my 1951 Minneapolis Moline BF that I bought last Jan, the engine compression will be nearly zero. If it doesn't start, do a quick compression test on the cylinders to see if there's any hope of getting it going. If not, you'll be winching it onto your trailer.
hey thanks for the info and the link1 I will be heading up there in two weeks to claim my "prize" so I will return with many more questions in the future!
/ starting an old tractor for the first time in 15 years #8
What do you have for a trailer and tow vehicle?
/ starting an old tractor for the first time in 15 years #9
I'm surrounded by 4 JDs but mine is the only lot with 3 Kubotas .
Personally if it is not frozen I pull the coil wire and either try to pump up the pressure by the starter or I pull it a little. I have even been known to put some top lube in and keep the plugs out a little while.
Old pony motor/ dozer trick that adds life to motors. 90% of engine wear in non-lugging situations is at the start up. I usually spin any motor a little with the gas off if it has not been started in a little.
/ starting an old tractor for the first time in 15 years #10
put some atf oil inthe cyls and let set a bit then spin by hand to make sure nothing is siezed.. do an oil and filter change too, before starting..
soundguy
/ starting an old tractor for the first time in 15 years #11
might need something to air up the tires.:D
/ starting an old tractor for the first time in 15 years #12
EV;
Get a winch or a come-along and drag it on the trailer. Then you can bring it home and spend some quality time changing fluids and pre-oiling the cylinders, pumping up tires and all the other stuff you won't have time for over a weekend, five hours away from all your tools, etc. I love dragging home old stuff and getting it working again. Good Luck.
SimS
/ starting an old tractor for the first time in 15 years #13
Make sure the throttle blade is free, You don't want that thing sticking at WOT!!!
Thanks for all the help guys! Yea I think I will just drag it home and put it in my shop so I can devote some real time to diagnosing any trouble that could show up. I am able to borrow a 16 foot car trailer from work and i own a heavy half ton pickup, so getting it home won't be to hard a haul. Also the father in law has a 970 case with a loader wich we will use to pulll it onto the trailer. Thanks again
/ starting an old tractor for the first time in 15 years #15
Something no one else has mentioned....once you know its "free" and turns over easily without the plugs, and you have spark, put the plugs in and give the carb a quick shot (not much) of starter fluid...at that point you will know whether it wll run or not once you get gas to it...Good luck! BobG in VA
/ starting an old tractor for the first time in 15 years #16
I think that you are on the right track get it loaded and home before trying to start it.
It would seem to me that a lot of the questions you are raising could be answered better by your FIL. Undoubtedly he knows more about the tractor than we do.
Steve
Well, I finally got the tractor home! Before I spend too much money on fixing up the tractor, I am going to try and start it. What i have done soo far is turn over the motor by hand and then hooke it up to a battery charger (no battery in the tractor yet) and was able to get it to turn over successfully. But i believe that there is no spark. I do not have a spark plug socket yet to pull the plugs out but i pulled off one of the wires and did not get a visable spark. I can smell gas thru the exhaust so i figure that fuel is getting to the cylinders. I then pulled off the distb. cap and scratched the points but all looked pretty clean, i also tried to measure voltage on the line side of the coil but got no reading. What should be my next step? In the AM I thought ablut checking the genny and the regulator? Any points will help, do I need a battery installed to polarize the coil as I have been reading on this site abiut this too? Thanks in advance
/ starting an old tractor for the first time in 15 years #18
get a battery on it before trying to start it.. even a booster charger with a start option is not enough power for the ignition and the starter.. even yer truck battery should do for a test.. heck.. throw the booster on as well.
soundguy
/ starting an old tractor for the first time in 15 years #19
207271 (A52708)
207271 (A52708)
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
Brush Cutter Mini Skid Steer Attachment (A59228)
Brush Cutter Mini...
5' ROTARY MOWER (A60430)
5' ROTARY MOWER...
Honda EM3500S...
PALLET OF BRAIDED HOSE (A60432)
PALLET OF BRAIDED...
