Do I need a slip clutch?
   / Do I need a slip clutch? #21
2$ yikes.. are your shear bolts / pins something special that you can't use a soft grade 2 bolt in place of.. 2$ buys alot of grade 2 bolts!
soundguy
OK...I guess I was a little off on my price. $0.70 a piece at lowes for 1/2 x 3" cheapies. Still though, shearing a few bolts per job plus time spent swapping pins and a slip clutch could be paid for in no time. I still use shear pins though:eek:
   / Do I need a slip clutch? #22
soundguy
The shear bolt for the 403 is a 8.8 grade M8x45. I thought it was a soft grade 2 till, well you know:D Dont remember the cost it was less than a dollar at the napa for bolt, nut.
   / Do I need a slip clutch? #23
You may already know this, but a metric grade 8.8 is the equivalent of our SAE Grade5. But 45mm sounds kinda short for a shear bolt, that's barely an inch and three quarters.
//greg//
   / Do I need a slip clutch? #24
sounds like it may be a flange style shear bolt vs one that is thru a shaft and collar.
soundguy
   / Do I need a slip clutch? #25
no argument.. the slip clutch is more desireable.
the cost of the shear bolt itself is nothing compaired to the cost of the downtime replacing the darn thing..
soundguy
   / Do I need a slip clutch? #26
@Bramble, the PTO over-ride/over-run coupler is a must for any older live PTO tractor.......without it the energy of the implement can be directly transmitted right back into the tranny long after you've hit the clutch and/or the turning brake whick can buffet the tractor along.
As for a slip-clutch, it's great but not near as necessary as the over-running coupler. In 20 plus years of shredding (brush-hogging) I've yet to break a shear pin. Ever. All of my cutters have the original pins in them and that's cutting everything from thin pasture grass to 1" material. I did break one shear pin on a post hole digger years ago in some serious rock. I've gotten cutters hung up on rocks before and broken the 3-pt assembly...........but not the shear pin.
Truly makes me wonder what some people are doing with their 'quipment sometimes.
   / Do I need a slip clutch? #27
Joe, What were you running for tractors in those 20 years? I bush hogged for 5 years with my Ford 841D on the same shear pin, traded for the Kioti DK45S & broke 3 pins the first hour. Live electric PTO is much different than the old Ford. I broke pins from too much power-much too quick. Same shear pin since adding the slip clutch & learning to idle down before engaging the pto. Over running coupler is pointless on tractors with live pto. MikeD74T
   / Do I need a slip clutch? #28
@Bramble, the PTO over-ride/over-run coupler is a must for any older live PTO tractor........
I agree with mike.. if you have live pto.. ORC isn't needed.
If you have independent pto and want to save your pto break you can use an ORC.
soundguy
   / Do I need a slip clutch? #29
//greg//
That I did not know greg_g, and yes its short:D And as sound points out, it is a flange type shear, not a collar-shaft type. For replacing sheared bolts, its not as bad to remove busted pieces as threw a collar-shaft stile. Still got to stop, get off tractor....... Clutches rule.
   / Do I need a slip clutch? #30
With that short of a bolt I was thinking it had to be flange.
any idea if that is an oem shaft on that mower or a replacement one?
soundguy
(APPROX. 20) 4' X...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Westendorf TA-29 Loader (A59814)
Westendorf TA-29...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2013 Ford C-Max Energi Hybrid PHEV Hatchback (A59231)
2013 Ford C-Max...
*Selling at Royal Auction Tampa, FL Location* 7 (A59228)
*Selling at Royal...
