Ratchet Rake - ever seen/used one?
   / Ratchet Rake - ever seen/used one? #41
Thanks that would sure be a better choice
   / Ratchet Rake - ever seen/used one? #42
Eric - Once I receive the rake and test it out, I'll send you a PM. I don't mind at all if you want to see it for yourself.
Thanks Thavil - I appreciate the offer! I might jump the gun and just order it since it takes a couple of weeks - I could really use it soon....
   / Ratchet Rake - ever seen/used one? #43
No problem on the offer Eric.
I just got home and checked my email. I received an email late last night from Barabara saying the rake was sent via UPS ground and the ratchet straps,protectors and product information sheet was also sent the same day via USPS Priority Mail. So far, so good, same next day shipping as I ordered the rake on Sunday. I just checked the UPS tracking website and it should arrive tomorrow!!
   / Ratchet Rake - ever seen/used one? #44
Got home late from work tonight and the rachet rake was waiting on my doorstep along with a box that has the straps and product information sheet. Ordered on Sunday and receive both on Wednesday! Also had an email from the inventor, Brad, that explained some of the concerns from this thread about the hydraulic cylinder when using this product. Below is part of what the email said:
Our product information sheet instructs the user to operate the bucket in a tilted position, but only when backdragging (the longer trailing teeth limit the shorter teeth from over penetrating. This allows the Ratchet Rake to be operated backwards in a smooth and uniform manner). Also, we instruct the user to limit the angle that the bucket should be tilted to 30-50 degrees (not 90 degrees with the hydraulic cylinders fully extended). Finally, in areas where large embedded rocks or debris may be present (that could force the machine to come to a sudden dead stop upon contact) we recommend a 2 mph speed limit.
I will not get a chance to try out the rachet rake tonight since we got a lot of rain today. I will say that it is very heavy duty. More to come tomorrow.
Tod
   / Ratchet Rake - ever seen/used one? #45
Excellent turnaround time - since I've procrastinated, I think I'll wait for your review. That and I have decided to check out the contractor's auction in Brandywine this weekend - so my priorities may change......:D
   / Ratchet Rake - ever seen/used one? #46
Looking at one as well, as our field/yard at the newly constructed house needs a bunch of sod ripped out, and a fenceline filled with brush/briars/twigs etc.. sounds like this might be the perfect ticket...
   / Ratchet Rake - ever seen/used one? #47
The rake in the earlier days, was bolted to the lip of the bucket like this.
The second pictureis shows how the straps and chain are attached.
   / Ratchet Rake - ever seen/used one? #48
JJ: Do you have one of these? If so, where have you been?
   / Ratchet Rake - ever seen/used one? #49
No, I don't have one yet, but I have a 1000 ft road that could use something like this.
   / Ratchet Rake - ever seen/used one? #50
Tod
OK Tod, it's tomorrow. It's almost 7PM!!:rolleyes: Where is the info from a man that has actually touched one? There are alot of us counting on you.:) Don't let us down or keep us hanging. Don't act like you have more to do than keep your fellow Kubota owners that need/want a ratchet rake informed concerning your purchase.:) Come on Tod, report in!!! Where are you Tod? Are you there? Anyone have Tods home phone number? Call him!!:)
2014 Ford Fusion SE Sedan (A53424)
2014 Ford Fusion...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A55302)
2019 Krause...
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A55301)
2014 Doyle Dry...
2018 KENWORTH T270 SERVICE TRUCK (A51406)
2018 KENWORTH T270...
