Want to install a selector valve on 4110
   / Want to install a selector valve on 4110 #11
Willman, how did you make out, did you add the Price 2 way manual selector (20 gpm/2500 psi) valve between the power beyond port and the two hoses (BH & remote)?
I need to do the exact same set up as you describe in your first post, but have minimum knowledge with hydraulics. I want to be able to switch from one to the other, such as with a button or lever manual selector valve.
Can anyone give me a link of the appropriate valve required, as I do not know what type is best, but want the smallest manual button or lever valve as possible.
   / Want to install a selector valve on 4110 #12
Here is the valve Willman was talking about:
Amazon.com: Prince SS-2A1D Two Position Selector Valve: Home Improvement
Shop around and I think you can beat this price.
Rusty
Edit - Here is a site with better pix and better price: http://www.drillspot.com/products/41147/Prince_SS-2A1D_Two_Position_Selector_Valve
   / Want to install a selector valve on 4110 #14
Rusty and Kenny I appreciate your help as I am not fimiliar with hydraulics and or valves. I have no problem doing the hook up ....just was not sure of the proper selector valve needed to perform the dual function.
Thank you.
Just ordered it.
   / Want to install a selector valve on 4110 #15
I just did for you...Surplus Center has it for much less, and you can get all the fittings from them also.
Kennyd - Sure did beat the prices I found and from a site sponsor too!
BillBee - Let us know how it works out. I'd like to see where & how you mount it as well as hear if you end up satisfied with its convenience and functionality.
Rusty
2024 CATERPILLAR 259D3 SKID STEER (A60429)
2024 CATERPILLAR...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56438)
Neckover GL24-2-7K...
2018 John Deere Z997R (A53317)
2018 John Deere...
