Want to install a selector valve on 4110
   / Want to install a selector valve on 4110 #11
Willman, how did you make out, did you add the Price 2 way manual selector (20 gpm/2500 psi) valve between the power beyond port and the two hoses (BH & remote)?
I need to do the exact same set up as you describe in your first post, but have minimum knowledge with hydraulics. I want to be able to switch from one to the other, such as with a button or lever manual selector valve.
Can anyone give me a link of the appropriate valve required, as I do not know what type is best, but want the smallest manual button or lever valve as possible.
   / Want to install a selector valve on 4110 #12
Here is the valve Willman was talking about:
Amazon.com: Prince SS-2A1D Two Position Selector Valve: Home Improvement
Shop around and I think you can beat this price.
Rusty
Edit - Here is a site with better pix and better price: http://www.drillspot.com/products/41147/Prince_SS-2A1D_Two_Position_Selector_Valve
   / Want to install a selector valve on 4110 #14
Rusty and Kenny I appreciate your help as I am not fimiliar with hydraulics and or valves. I have no problem doing the hook up ....just was not sure of the proper selector valve needed to perform the dual function.
Thank you.
Just ordered it.
   / Want to install a selector valve on 4110 #15
I just did for you...Surplus Center has it for much less, and you can get all the fittings from them also.
Kennyd - Sure did beat the prices I found and from a site sponsor too!
BillBee - Let us know how it works out. I'd like to see where & how you mount it as well as hear if you end up satisfied with its convenience and functionality.
Rusty
IRTPL LIFT (A58214)
IRTPL LIFT (A58214)
2020 Case 5550 Trident (A56438)
2020 Case 5550...
Mayrath 10 x 72 Swing Away Auger (A59814)
Mayrath 10 x 72...
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A56438)
2002 Chevrolet...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
2019 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2019 MQ POWER...
