Want to install a selector valve on 4110
   / Want to install a selector valve on 4110 #11
Willman, how did you make out, did you add the Price 2 way manual selector (20 gpm/2500 psi) valve between the power beyond port and the two hoses (BH & remote)?
I need to do the exact same set up as you describe in your first post, but have minimum knowledge with hydraulics. I want to be able to switch from one to the other, such as with a button or lever manual selector valve.
Can anyone give me a link of the appropriate valve required, as I do not know what type is best, but want the smallest manual button or lever valve as possible.
   / Want to install a selector valve on 4110 #12
Here is the valve Willman was talking about:
Amazon.com: Prince SS-2A1D Two Position Selector Valve: Home Improvement
Shop around and I think you can beat this price.
Rusty
Edit - Here is a site with better pix and better price: http://www.drillspot.com/products/41147/Prince_SS-2A1D_Two_Position_Selector_Valve
   / Want to install a selector valve on 4110 #14
Rusty and Kenny I appreciate your help as I am not fimiliar with hydraulics and or valves. I have no problem doing the hook up ....just was not sure of the proper selector valve needed to perform the dual function.
Thank you.
Just ordered it.
   / Want to install a selector valve on 4110 #15
I just did for you...Surplus Center has it for much less, and you can get all the fittings from them also.
Kennyd - Sure did beat the prices I found and from a site sponsor too!
BillBee - Let us know how it works out. I'd like to see where & how you mount it as well as hear if you end up satisfied with its convenience and functionality.
Rusty
2009 Hyundai Sonata Sedan (A59231)
2009 Hyundai...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
iDrive TDS-2010H...
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
2008 Ford F-350 4x4 Ext. Cab Knapheide Service Truck (A59230)
2008 Ford F-350...
207270 (A52708)
207270 (A52708)
