HST issue
   / HST issue #1
Mculby
Member
Jamestown, IN
Kubota L4400-1 HST
I think something is going on with my HST. I have an L4400 with just 20 hrs on it and after mowing about 5 ac this weekend with a 72" bushog the hst makes a rattling noise when it is not moving and the HST pedal is in the neutral position. The rattling sounds like it is coming from a small hydraulic line under the left area where your foot sits. Once I put any pressure in forward or reverse on the pedal then the noise stops. Is there a check valve or something under the left foot area that could be rattling?
   / HST issue
Yep checked for loose lines and bolts all the fluid is full as well. When I was checking for loose items is when I discovered the small metal hydraulic line under the left foot area that seemed to be rattling when I was touching it but nothing was loose.
   / HST issue #4
Is there a loose bracket holding the line? Is the line vibrating and touching something? Grab the line and hold it when in neutral to see if it stops.
   / HST issue
Yep I checked all the brackets and held the lines. There are no lines that are loose. It looks like a T with a small 1/8" or so hydraulic line coming from right under the left foot well that was rattling. If I can take a picture and post it I will. But it seems to have stopped now, but it only did it after I had ran the tractor with the mower for a few hours.
   / HST issue #8
Redneck....
re: your signature.
I guess that I live in the country. Been there, done that!:D
Vernon
Oops OT, sorry
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58214)
2014 MAGNUM...
2022 CATERPILLAR PM622 COLD PLANER (A60429)
2022 CATERPILLAR...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
