HST issue
   / HST issue #1
Mculby
Jamestown, IN
Kubota L4400-1 HST
I think something is going on with my HST. I have an L4400 with just 20 hrs on it and after mowing about 5 ac this weekend with a 72" bushog the hst makes a rattling noise when it is not moving and the HST pedal is in the neutral position. The rattling sounds like it is coming from a small hydraulic line under the left area where your foot sits. Once I put any pressure in forward or reverse on the pedal then the noise stops. Is there a check valve or something under the left foot area that could be rattling?
   / HST issue
Yep checked for loose lines and bolts all the fluid is full as well. When I was checking for loose items is when I discovered the small metal hydraulic line under the left foot area that seemed to be rattling when I was touching it but nothing was loose.
   / HST issue #4
Is there a loose bracket holding the line? Is the line vibrating and touching something? Grab the line and hold it when in neutral to see if it stops.
   / HST issue
Yep I checked all the brackets and held the lines. There are no lines that are loose. It looks like a T with a small 1/8" or so hydraulic line coming from right under the left foot well that was rattling. If I can take a picture and post it I will. But it seems to have stopped now, but it only did it after I had ran the tractor with the mower for a few hours.
   / HST issue #8
Redneck....
re: your signature.
I guess that I live in the country. Been there, done that!:D
Vernon
Oops OT, sorry
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
SCAN TO RECEIVE TEXT UPDATES (A60430)
SCAN TO RECEIVE...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2014 Ford Explorer AWD SUV (A59231)
2014 Ford Explorer...
