HST issue
   / HST issue #1
Mculby
Jamestown, IN
Kubota L4400-1 HST
I think something is going on with my HST. I have an L4400 with just 20 hrs on it and after mowing about 5 ac this weekend with a 72" bushog the hst makes a rattling noise when it is not moving and the HST pedal is in the neutral position. The rattling sounds like it is coming from a small hydraulic line under the left area where your foot sits. Once I put any pressure in forward or reverse on the pedal then the noise stops. Is there a check valve or something under the left foot area that could be rattling?
   / HST issue
Yep checked for loose lines and bolts all the fluid is full as well. When I was checking for loose items is when I discovered the small metal hydraulic line under the left foot area that seemed to be rattling when I was touching it but nothing was loose.
   / HST issue #4
Is there a loose bracket holding the line? Is the line vibrating and touching something? Grab the line and hold it when in neutral to see if it stops.
   / HST issue
Yep I checked all the brackets and held the lines. There are no lines that are loose. It looks like a T with a small 1/8" or so hydraulic line coming from right under the left foot well that was rattling. If I can take a picture and post it I will. But it seems to have stopped now, but it only did it after I had ran the tractor with the mower for a few hours.
   / HST issue #8
Redneck....
re: your signature.
I guess that I live in the country. Been there, done that!:D
Vernon
Oops OT, sorry
2007 Ingersoll Rand G240 240kVA 3-Phase Towable Diesel Generator (A59228)
2007 Ingersoll...
2003 INTERNATIONAL 9900I (INOPERABLE) (A58214)
2003 INTERNATIONAL...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
YANMAR VIO35-5 UNIVERSAL EXCAVATOR (A60429)
YANMAR VIO35-5...
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
