What attachments did you THINK you needed but don't use much?
   / What attachments did you THINK you needed but don't use much? #91
I have some questions for you guys that prefer your FEL to a box blade. What type of grading are you doing with your FEL? What do you do when you need one side lower than the other? :confused:
I use the Tilt Tach. Great when using forks too.
larry
   / What attachments did you THINK you needed but don't use much? #93
   / What attachments did you THINK you needed but don't use much? #94
Let some air out of the tires on one side? ;)
I guess that would be one way to do it. My guess is that they don't have a need for any custom grading, thus they can get what they need done with their FEL, and that is fine. I know that I would HATE to only have my FEL for grading.
   / What attachments did you THINK you needed but don't use much? #97
I thought you were supposed to put taller tires on the side you wanted higher :)
   / What attachments did you THINK you needed but don't use much? #98
Ok, but then you better only have 1 wheel drive, or you going to have huge drive line binding. :eek:
   / What attachments did you THINK you needed but don't use much? #99
Funny. I was just wondering if they are both the same person.
Eddie
Geeze, give a guy a break. The other person you are comparing me to does this continuously, and I respond to a couple of postings on the same thread, and I get compared to Mr. Gotta-respond-to-every-post-even-if-it-is-a-meaningless-on-word-comment :rolleyes:
   / What attachments did you THINK you needed but don't use much? #100
I've got a 4n1 bucket on the FEL, and still often have the box blade on at the same time. They do different things, and even though its subtle, its still useful.
I actually have a 2 rakes on the m59 now - skidsteer rake in front, 3ph rake behind. They actually do things slightly differently to the point its nice to have both.
As for useless, given that I've never actually used my fertilizer/seed/spreader, I'd have trouble justifying it... I think this might be the year it gets a use. For me, a push scotts spreader would have been fine.
Unused 2025 CFG Industrial MH12RX Mini Excavator (A59228)
Unused 2025 CFG...
SKID STEER ATTACHMENT AUGER (A58214)
SKID STEER...
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
2026 Quality steel dump truck (A56859)
2026 Quality steel...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
